Old 08-05-2003, 09:00 AM
tanman328 tanman328 is offline
Newbie - Detail Painting
First off, I'm incredible impressed with all the talent on this forum. The models I've veiwed are just fantastic.
As a newbie to the car modeling world, I would like to get more advice on detailing. In particular, the use of brushes to paint small areas on the vehicle such as the interior. I am still having a great deal of trouble of painting within the lines. How do you guys do it so incredibly clean? Do you mask everything (even the smallest details) and brush paint? Do you primarily airbrush everything?
Secondly, I've been using tamiya acrylic paints when brush painting, and having trouble getting the paint pigment to stick. The end result is me always ending up putting too much paint on the part and looking unnatural and ugly.
Do you modeling wizzes have any advice?
Old 08-05-2003, 09:53 AM
egon_dude egon_dude is offline
Send a message via MSN to egon_dude
For detail painting, the first thing i would recommend is to use Humbrol or Testors Enamels rather than tamiya acrilics- they take longer to dry and they adhere better to the plastic so they dont pull off as easily when you brush over them. It will make your painting look a lot cleaner.
Secondly, the brushes you use are key. I use Daler-Rowney Dalon brushes, which are artificial sable-hair artists brushes. I use a size 1 and a 00, plus a "rigger" brush, which is a very fine brush with 1-inch long hairs. I use this to the black lines round windows, as the long hairs damp out the wobblyness of your hand and you can paint staright lines pretty easy. You can get these brushes from any decent art shop, and are much better than the cheap rubbish you get in most model shops, but not much more expensive (about £2.50 each).
Thirdly, PATIENCE! If the part doesnt look right at first, wash the paint off with some thinners, let it dry and have another go. Keep practicing, and you will get better at it, trust me!
good luck!
Old 08-05-2003, 11:08 AM
MrHappy's Avatar
MrHappy MrHappy is offline
Send a message via Yahoo to MrHappy
Get your self a good brush and practice.
Also look after your brush.. Clean thoroughly after every use and bring to a point between your fingers... Always store it away with the end cover tube on (if it came with one).
It should last you a long time if you do.
I also find thinner paint flows better from the brush even if I have to apply a few coats it always looks cleaner.
Have fun..
Old 08-06-2003, 02:27 AM
Sennake's Avatar
Sennake Sennake is offline
[list=1][*]Always use good quality brushes. Rather buy 2 expensive ones than 5 or 6 cheap ones. I always use "real marten hair" brushes.[*]When you try to paint straith lines and you have a "wobbely" part, you can also correct the wobbely part with a toothpick. Drench it in some white spirit or thinner and correct the excessive paint. That is a lot easier than making corrections with a brush.[*]Once finished, make sure to thouroughly clean your brushes. This means cleaning and wiping several times. Usually I clean my brush 4 to 5 times. After cleaning another small trick : put some spit on your fingers and go between your wet fingers with the brush before putting it in its protective tube again. that will keep its shape a lot longer.[/list=1]
And of course : practice, practice and practice! I am starting to be able to paint some straith lines now, but I have been modeling since I was 9 years old and I'm 42 now...
* WWW.SENNAKE.BE *
Old 08-06-2003, 07:03 AM
shieldwulf's Avatar
shieldwulf shieldwulf is offline
Originally posted by egon_dude
... I use Daler-Rowney Dalon brushes, which are artificial sable-hair artists brushes... good luck!
I used to think that Tamiya tools, paints and brushes are the best of the best. I was wrong. When I tried a C10 Daler-Rowney CRYLA brush, it knocked the socks off all my collection of fine-tip brushes (I have the complete set of Tamiya HF set of brushes). I used the Daler-Rowney brush in Tamiya Acrylics and Enamels and washed it using Tamiya Acrylic & Enamel Thinners, and even normal hardware store Lacquer thinners. All in all, this brush manages to retain its fine pointed tip even when dried. I found the Tamiya brushes to "open up" quite a bit after first use. Worse, some hairs of the Tamiya's can go "berserk", and I will need to trim them off.
Old 08-06-2003, 07:23 AM
Can you get Daler-Rowney CRYLA brushes in Singapore? Given that I'm in Malaysia could you recommend some of your fav. hobby stores in Sin. I'm having trouble just finding enamals in Malaysia.
Old 08-06-2003, 01:07 PM
shieldwulf's Avatar
Hi,
I got my Daler-Rowney CRYLA brush from Art Friend at Bras Basah Complex. Should be at level 3 I think. However, Art Friend also has other branches in Singapore but I cannot recall.
Art Friend at Bras Basah carry a wide range of artist products like enamels, acrylics, airbrushes, styrofoams, art raw materials etc. Except that they don't carry any scale modelling hobby brands and products. Don't expect to find Gunze or Tamiya products there.
Daler-Rowney website
Old 08-06-2003, 01:26 PM
Harlock Harlock is offline
Brushes are key. I have always been told, also, that when storing your brushes make sure you do it bristles up.
Old 08-07-2003, 01:46 AM
rx7king's Avatar
rx7king rx7king is offline
do any of you mask your parts for your hand brushing?
