1996 chevy lumina cruise control not working anymore. Any have any good troubleshooting or know where to start diagnosing this problem?
Fuses.. vacuum lines..
justin - '94 GP SE sedan - '89 GP LE coupe |
:iceslolan Cruise 96 3.1 inhibit
On my 96 Lumina 3.1L I had this problem.
My fuel pump was going out, and did not put out the 80 PSI needed. Also the service engine soon light came on due to a transmission shift problem. With the Service Engine Soon lamp on, the cruise was inhibited. Reset light with OBD II and then see if cruise works again, check fuel pressure Scot KD5DGS |
>>Reset light with OBD II and then see if cruise works again, <<
Please tell me what OBD II means and where it's located. Thanks |
Re: cruise not working - engine light on
On my lumnia the 16 pin test port is below the steering wheel on the lower trim. in short, you plug in a hand held reader control box to find out what is going on inside the brain of your car |
Cruise Not working
Thanks for the reply. Maybe that'll do the trick.
kenn |
