| Maintenance problems, fixes. |
I recently bought this g20 w/ 65000 miles and it ran fine all except for a low idle when stopping or turning. I replaced the fuel filter, air filter (K&N), oil filter, and oil. I also ran fuel injector cleaner through the gas tank. The engine was dirty too so i washed it off really good and made it shiny....oops. After driving about 25-35 miles after doing all this it started riding REALLY REALLY rough, no acceleration, and less than half the previous MPG. I assumed that the problem was because of the fuel injector cleaner (Wyyms cleaner) because the fuel filter was secure as well as the air filter. I had read that the injectors in this engine did not need injector cleaner unless necessary and I considered it very necessary considering my car was shutting off when the rpm's went low. It started getting really bad so I reset the ECU (disconnected battery for 1/2 hour) and that didnt fix anything so I broke down and took it to Dreyer & Reinbold Infiniti (Indianapolis, IN) who told me that the spark plugs had been flooded because I cleaned the engine!! They didnt charge me the $35 inspection fee, but wanted $220 to replace the plugs and wires!!
that. The tech suggested covering the plugs with a shammy or something and using compressed air to blow out any water left in the cavities after detailing the engine. I am going to replace the plugs and wires myself (Bosch Platinum plugs) but did not know what wires would be good to use. I am planning on autocrossing with this car so what would some good wires be that are within a reasonable price.
the stock wires are supposedly better than any aftermarket for the SR20.
NOOOOOOOOOOOOOOOOOOOO
Dont buy Bosch plugs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
They suck @$$ I thought it was quite ridiculous when they told me that the first fix for my baby was some plugs! I looked and laughed at them. They then told me if they put the plugs in and I dont notice a diference they will pay for the plugs and it made a quite reasonable difference. I know that no other car company besides MB and BMW probably pay even close to that amount for a set of spark plugs but I'm telling you from experience that its true! They do work and the Bosch cant handle the heat that the NGK platinums do. I'm telling you ask anyone on the forum and they'll tell you Bosch suck! They are cheap but an ol' sayin always makes you see the light. "You get what you pay for!" Believe that!
Women call my bedroom the COCKpit! |
You can get the NGK Platinums or the NGK Coppers. They both work great in the SR20's and are both listed as stock in your owners manual.
The platinums are PFR6B-11, 60,000 miles, and cost $35-$40 a set The coppers are BKR6E, 15,000 miles, and cost $5-$8 a set I opted for the coppers due to the price. if you get the coppers, make sure they are the exact part # above and not the BKR6E-11. Wrong gap for the coppers in the SR20's. The factory wires cost around $40-$45 through the dealer. Try to blow the water out with compressed air or suck it out with a wet vac. You should be ok. Tell Dreyer & Reinbold to go %^& themselves. err! Uh! well! Yeah! $220 my ass!
Brandon '96 G20 - modified |
I did the same thing russdye did ( Cleaned my engine). I noticed that the engine has been idling rough and that there is no acceleration but my MPG is up from before is this caused by the spark plugs also and is it bad to keep driving this way. Any help would be much appreciated.
use compressed air to clean the spark plug wells.
i had bosch plugs in for around 8k miles. they were nice at first, but then i realized why everyone around here is against them. replaced them w/ ngk plats and love them. bosche plugs can lick my ass-get the ngks-no question.
i accidently got water in my wells and sucked it out w/ a wet/dry vac. i just put a little tube on the end, duck taped it shut and sucked. worked very well.
93.5 G20 Life is like a shit sandwich. The more bread you have, the less shit you taste. So go out and get your bread! |
How hard is it to change spark plugs ? I have never done anything like that and should I change wire too ?
Just got head and tranny work done and the car runns great while rolling but is idling funny ...
93.5 G20 JDM SPEC SR20 JWT POP CHARGER GROUND CONTROL/KYB ADJUSTABLES 17" VOXX MGR 205/40/17 |
Rough idle
Have you ever cleaned out the throttle body etc??
If you dont eat, ya dont shit. If ya dont shit ya die |
( I know I sound Dumb ... hard to beleive I am one test way from MCSE )
Are any of the aftermarket wires really any good ? I want to work on mine ASAP... I read alot about NOXOLGY wires and MGR's ... ????
. ya you need a torque wrench and a spark plug socket. its so you dont overtighten the spark plug and break it by tightening it too much. wire, i mean spark plug wires, just look at the end of the wire where the top of the spark plug goes into, if you see rust or corrosion, replace it, it might not be firing right (making enough spark = lose in power). dont worry, at one point, i never knew this stuff either ![]() Quote:
never heard of MGR. who knows, they might show some power gains, but id stick with stock.
Stick with OEM. All the other aftermarket wires are no better than OEM at best, and most are far worse.
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
Until you run a stupid fast turbo set-up (not even a mild DET), stick with all stock ignition. I've heard of people putting in NGK plugs and OEM wires with 100k miles on them, replace nearly new parts (non-NGK and non-OEM) and their driveablity and idle problems went away.
If that doesn't convince you to stick with NGK and OEM, then I have a Tornado to sell you.
