Old 08-05-2003, 03:25 AM
TC23 TC23 is offline
Angry decks
i have a 2002 cavalier, i wanted to get a deck but stores tell me that i have to keep the head unit hooked up in the vehicle otherwise my airbags will not work, my remote keyless wont either. So they say it will be an extra charge to have it installed in the trunk, is this true and if so, is there a way to bypass this and not have to have the head unit in the trunk
Old 08-05-2003, 03:20 PM
redmen57 redmen57 is offline
Send a message via AIM to redmen57 Send a message via Yahoo to redmen57
i think u have to hooked it up in the trunk there is no way aound it its like that with alot of new cars especailly cavaliers n sunfires. i think u should just take it to some one else that wont charge u extra to hook it up in the trunk. i think that is rediculus they charge u for installation then they charge u more installation because they have to put the old deck in the trunk. o n by the way make sure once they change it that u can turn ur key backwards to accessories n the deck will come on. for some reason my aunt got screwed n her's doesnt work when u turn the key backwards. if it doesnt then u know what to do
www.z24v6.com
or maybe its
www.v6z24.com
Old 08-06-2003, 08:46 AM
mcleod13 mcleod13 is offline
Send a message via AIM to mcleod13 Send a message via Yahoo to mcleod13
I just went thru the whole process but did it myself.. I had to go to Circuit city and purchase a relocation kit, smart harness, and a antenna adapter... You have to hook up it all together and run the wife to the relocation harness to the trunk and hook the factory stereo to it. Then you have to hook the red wire to the fuse box. It is a rather easy process.. if you have any more questions feel free to ask me.
Feel free to give me all the advice you want. I am new to this and need lots of help
Old 11-12-2003, 01:57 AM
azcavalier azcavalier is offline
Send a message via Yahoo to azcavalier
I had read numerous times about the airbags not working and asked someone I knew at a dealership and said that wasn't true. My aftermarket deck was put in my car in July 2003 and the airbags are still operational(at least as far I can tell since I haven't wrecked) and they haven't deployed accidentally either. I found the below links very helpful in removing the dash and installing aftermarket deck in my 2001 cavalier. Hope this has been some help. I am getting ready to take it apart again to install xm.
http://www.carstereohelp.org/stereor...alier2StrR.htm
http://www.ny-jbodies.org/forum/libr...he%20dashboard
Old 12-26-2003, 10:40 PM
onetime_77 onetime_77 is offline
Send a message via Yahoo to onetime_77
you do not have to keep the factory deck running in order to keep all your safety features. I believe the only thing that stops working is the door buzzer and most people don't like them anyway. If you really want to keep it there is a way to reroute that wire, but I am not sure. I am just going off what others have done. I had a friend that didn't reinstall his factory deck in the trunk and according to his rearending a suburban....airbags work fine.
Old 12-27-2003, 01:38 AM
MtLeCe MtLeCe is offline
Send a message via AIM to MtLeCe Send a message via MSN to MtLeCe Send a message via Yahoo to MtLeCe
Re: decks
My car wouldn't shift outta first gear when I didn't relocate my headunit in my '04 cavy....
Matt~
Old 01-01-2004, 11:53 PM
obie_17 obie_17 is offline
ok people heres the deal, i professionally install car audio at a well known company, i've been doing it for about 3 yrs now both professionally and on the side. I used to own a 2002 Cavalier i installed the radio my self (did not relocate factory radio), my wife owns a 2003 cavalier i installed a radio in her car also BUT (i also did not relocate the factory) and not problems with the car so far, I now own a 2004 Cavalier and installed a radio (did not relocate factory) no problems with the car. Now all the roumors about it controlling the airbags is bull crap, and any other roumors are false. The only problem that you will run into is that when you hook up the aftermarket it will not work, the reason for that is that you will have to run a new accessory wire, so it will come on. hope this helps out...
Old 01-02-2004, 02:27 AM
Autoflow Autoflow is offline
I agree with obie i seen alot of people with new units that work fine without relocating the factory unit. The problem i have seen is alot of the time when its done on the side by the owners of the car the wires arent matched up correctly. recently i had someone who didnt know what to do with the extra black wire tie it in with the ground and fried the computer. Their are a few small things tied into the radio but nothing that will stop the car from running.
