Old 08-04-2003, 04:46 PM
jackacc's Avatar
jackacc jackacc is offline
OBD1 or 2
I know the y8 is OBD2 and I hear that the wiring is tricky. But I thought I was told that you can make the y8 OBD1 and it may be easier. Is this true? If so, what are the differences as far as the swap goes?
Old 08-04-2003, 05:14 PM
GTA's Avatar
GTA GTA is offline
Whee..
obd2 wiring is harder. Just use a z6 ecu and dizzy and obd0 to obd1 conversion harness and run it as obd1.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-04-2003, 05:32 PM
jackacc's Avatar
Cool, that is what I was hoping. And the correct ecu is the p28 correct ?? I heard there was some guy on HT that made the wiring harnesses, know anywhere else to get one? Thanks
Old 08-04-2003, 06:39 PM
jackacc's Avatar
Oh one more thing...
Will the dizzy from the z6 bolt up right to the y8? I thougt I heard only a couple of the holes line up...unless that was on another motor?
Old 08-04-2003, 06:42 PM
GTA's Avatar
GTA GTA is offline
Whee..
p28 is correct and im not sure about the z6 dizzy, i think it does. I know when you use a 88-91 si dizzy on a z6 only 1 bolt hole lines up until you modify one of the legs.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 08-04-2003, 06:57 PM
jackacc's Avatar
Thanks GTA,
I need to finds me a p28! And yeah, that is probably what I am thinking of with the si dizzy not lining up.
WTB: OBD1 DOHC vtec Dizzy and 92-95 obd1 ecu Juicy05 Classifieds 5 01-23-2006 04:03 PM
WTB: OBD1 DOHC vtec Dizzy and 92-95 obd1 ecu Juicy05 Classifieds 1 10-07-2005 01:36 AM
obd1 to obd2 questions... type r in 92 hatch hatchman Engineering/ Technical 0 05-05-2002 10:25 AM
obd1 to obd2 mikeowen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-30-2002 01:03 PM
