Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-04-2003, 02:21 PM
WillKool1080 WillKool1080 is offline
Turbocharger
I have a 1996 Cutlass Supreme 3.1L. I was wondering if anyone knew where I could find a turbocharger for it? If you do know of a place, if possible, post their website so I can check it out.
Thanks A Lot,
William
Old 08-11-2003, 10:11 PM
n4ji n4ji is offline
Send a message via AIM to n4ji
in 1990-91 Pontiac made a turbo grand prix with a 3.1 multi port turbocharged engine. It's a direct bolt in for the 3100SFI, start looking, I sitll haven't found one...
I'm a firestarter, twisted firestarter!!!
Old 08-20-2003, 08:45 PM
oswald oswald is offline
adding a turbo
Hi,
Adding a turbocharger to an engine which was originally built as non-turbo is quite a difficult and expensive process. Getting a turbo you want is only a small part of it. You have to decrease engine compression ratio, get a more efficient oil pump (turbocharger needs an effective oil flow ratio) and also the intake must be modified to sustain high pressure air intake. Pistons, crankshaft, camshaft and head also will sustain higher tensions as the engine will produce more power and torque. An intercooler would also be very needed. Not mentioning the transmission And so on.
So rather than adding a turbo you should consider getting a turbocharged engine. Of course building such engine gives you a lot of satisfaction (ratioof more than 100HP of 1 litre of capacity is highly possibe) and of course you have the only engine of a kind
Greetings,
John
turbocharger or supercharger J_U_ice Forced Induction 3 05-18-2009 09:07 PM
Twin turbocharging Vs. single turbocharging. Hypsi87 Non Specific 31 04-23-2005 08:26 PM
Overview: supercharger vs. turbocharger texan by texan (Brian) 28 11-23-2003 01:15 PM
Turbocharger v Supercharger Mr Roboto Engineering/ Technical 3 04-21-2003 02:36 PM
Anyone want to turbocharge their max? Why supercharge when you can turbocharge? 2k2max6sp Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 05-12-2002 11:15 PM
