Old 08-04-2003, 01:54 PM
jackacc's Avatar
jackacc jackacc is offline
passenger side mirror
I need to put on a passenger side mirror to "balance" out the std...
I did a search but did not find anything on the actual install... has someone out there done this or can give me a hint on how to get started? Will I have to take the inside of the door off? I just need to know what holds it on and where the bolts are at... thanks
Old 08-04-2003, 02:01 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: passenger side mirror
Well, mine came with a passenger side mirror (Si), but I'm sure it's very similar setup on yours. Basically, inside the car, there should be a little "triangle" shaped piece of plastic just inside the mirror. It should just pop off unless you see some screws or something. Once that is off, I'm sure you'll see some screws/bolts that hold the outer trim-piece that covers where the mirror would go... Remove that piece, and then the mirror should bolt right up. You will need to get a new interior trim piece with the hole in the middle so that the adjustment arm can stick through it (or just drill a hole in the one you've got if you're not too picky)...
That should probably do it, although, I've never actually seen an STD close up, so I'm not 100%, but I'm probably right anyways.
Old 08-04-2003, 02:11 PM
jackacc's Avatar
yeah, that was my main concern...was the plastic piece on the inside.. I was hoping it would just pop off but I figured before I go wrench on it and snap it in half I'll have to examine it closer tonight... most of the mirrors i have found come complete with the new inside plastic piece with the hole allowing for the adjustor plastic thingamabob...so I can just pop the new one in..I hope.. Thanks!
Need Help With Wiring of Side Mirror!!!! civdub21 How-To's and Walk-Through's 0 03-27-2009 07:05 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
looking for an 95-98 Passenger side mirror HondaSi88 Neon | Plymouth Neon 1 01-12-2003 01:51 AM
need a passenger side mirror on my 91 dx, what will fit Redline_civic91 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 09-16-2002 03:04 PM
Wanted: passenger side mirror for a 99+ G20 Nismoboy1 Classifieds 0 03-02-2002 04:44 PM
