Old 08-04-2003, 11:38 AM
sray454 sray454 is offline
Access to Radio
I'm triing to install an XM receiver, and am wondering what is the easiest way to get to the antenna lead connection at the radio ???
Old 08-04-2003, 01:29 PM
ChaosStarter ChaosStarter is offline
Send a message via AIM to ChaosStarter
you have to take the radio out to unplug the ant. connection from it. That'll plug into the FM modulator (which is what I'm guessing you're using) and then an ant. connection from the FM mod will plug back into the radio...
1999 Pontiac Grand Prix GTP (2dr)
"Gold" Package
~drop in K&N
~3.4" pulley
~drilled 180º T-Stat
~Casper's cooling fan switch
~U-bend/Resonator removed
Best 1/4: 13.58 @ 100.17 10/25/03
Best 60': 2.07 (stock RS-A's at 30psi)
Best Dyno: 5/3/03
197.4fwhp/262.4fwtq
Coming Soon....
turbo!!
Old 08-04-2003, 01:33 PM
So HOW do you get to the radio to take it out ???
Old 08-06-2003, 03:44 PM
The whole plastic dash in one big piece with a bunch of push-pins. Take off that whole piece (be careful not to break anything obviously) and the radio will be right there with 2-4 screws in it on each side of the radio. Unscrew those and pull that sucker out. The ant. will be the thick black plug.
"Gold" Package
~drop in K&N
~3.4" pulley
Best Dyno: 5/3/03
197.4fwhp/262.4fwtq
Coming Soon....
turbo!!
2002 galant es radio removal keytosilence Galant 1 07-26-2009 03:09 PM
99 Passat Radio Installation DouganAFife '97+ 0 04-15-2009 08:42 AM
2000 Cabrio Does not initially start, Radio Safe, Clock 1200 ptb123 Cabrio 0 04-11-2009 05:10 PM
1994 b-3000 radio removal zoobag General Discussion 1 04-05-2009 05:22 PM
1995-200? Lumina (GM) radio LED conversion saxonmor Car Audio 0 03-01-2009 09:59 PM
