Old 08-03-2003, 05:24 PM
Nosamulli Nosamulli is offline
Send a message via Yahoo to Nosamulli
Angry ABS and ETS lights 1996 Grans AM V6
i just replaced my rear brakes and now the abs light comes on...what did i do wrong. and if any one knows, is there a link where i can go online to down load a free repair manual>
Old 08-11-2003, 06:13 PM
Puckman27 Puckman27 is offline
yeah i've had the same problem w/ my 97 GT. i got new drums and rotors put on, and just about half of the time after i back up, the ABS light comes on. once i restart the car though, it goes off. that is until i back up and turn again. Does anyone know if this is a major problem or not?
Old 09-04-2003, 10:21 PM
jmjpro jmjpro is offline
I have the same problem but I changed my front pads and rotors. Have you found a fix to this problem yet?
It drives my wife crazy!
Old 09-05-2003, 10:25 AM
PT_Sean2 PT_Sean2 is offline
Have you checked the fluid at all??
Old 09-05-2003, 06:05 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Low flluid will turn on the red brake light not the ABS light.
You need to look at the wheel speed connector on the wheels you did brakes on. It is possible to knock the connector off or knock it loose.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 09-05-2003, 09:58 PM
where would I find the wheel speed connector?
Old 09-06-2003, 06:18 PM
Flatrater's Avatar
Main GM Guy
Speed connector is on the backside of the rotors. If you look at the control arm you will see the wires running up it and going under the hood of the car by the engine cradle.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 09-07-2003, 03:08 PM
96grandma's Avatar
96grandma 96grandma is offline
Send a message via AIM to 96grandma
i'm with flatrater on this one, it must be a lose wire. check and make sure everthing is hooked up on the wheels you did the brakes on
Old 09-10-2003, 08:43 PM
tinytt tinytt is offline
Question 96 grand am... ETS & ABS Lights on
I am also having a problem with my ETS Light.... which has been on for
almost as long as I have owned the car..which is one year...now the
ABS Light has come on... after driving the car for an hour or so... I
turn the car off and start it up... the light is off... after driving for a
while it comes back on... what is the problem ... any solutions? Thank you.
Old 10-01-2003, 10:31 PM
mike_drz mike_drz is offline
I've got a 96 grand am and i also had this problem after changing my front brake pads. LUCKLY I FOUND THE PROBLEM. At first it was supposed to be a wheel sensor in the front left tire that tells the computer how fast your wheel is spinning. It was supposed to cost $300 CND to fix. But my mechanic is a great guy he found that the wire going to the sensor was somehow cut and the sensor was fine. After that the ABS light never came on again, I don't know bout the ETS light.
Old 10-02-2003, 10:44 AM
Ares78's Avatar
Ares78 Ares78 is offline
Send a message via AIM to Ares78 Send a message via MSN to Ares78 Send a message via Yahoo to Ares78 Send a message via Skype™ to Ares78
usually if you take care of the ABS problem, the ETS light will go out as well.
Old 10-02-2003, 11:18 AM
Acutually now that i think back my ETS light did go on aswell, it's cuz the ABS system is tied in with the traction controll, the ABS goes on cuz the computer senses something is wrong with the wheel sensor. Just check the wheel sensor like I mentioned in my last post.
ABS and ETS issue randy78 Achieva 0 07-10-2007 01:00 PM
1996 Grand Am Quad4 Ele. Windows And Ets Light On emtjdj Grand AM 1 12-05-2005 07:30 AM
blinking odometer and ETS light ericed Cavalier 0 04-26-2004 02:53 PM
