Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-03-2003, 04:20 PM
gsrpower95 gsrpower95 is offline
custom turbo kit
Alright everything in the kit is brand new and has never been used at all except the synapse missing link valve which was used for 1000 miles. The payment is very negiotable, but I will require a down payment of 200 dollars if you are interested. The kit is basically completely ready, except for piping which is only 70 dollars and I will send you a link on were to get it from. Alright heres whats in the kit…..
1. Garrett T3/T4 Turbo- The turbos trim is a/r 50, it has an external 7 psi wastegate on it, and does come with the mounting gasket.
2. Custom FMIC- It is designed for most honda and acura applications, its tig welded, 2.5” inlet and outlet, it measures 30x6x3 tip to tip, and the core is 2 ¾” thick, which flows 33% more air than a 2” thick standard core.
3. Turbo Oil Feed Line- this is a complete kit to run from your block to your turbo, it will work for any b16 and b16 engines.
4. Custom Turbo Manifold- this manifold is tig welded with laser cut flanges, it will fit any b- series blocks.
5. NO WELD Turbo Oil Return Kit- this is a no weld oil return line, its great for aluminum pans, like honda and acura ones.
6. Greddy E-Manage- includes the greddy e-manage, support tools and software, ingintion harness, injector harness,sensor harness, and turbo pressure harness.
7. ALUMINUM Blow Off Valve- exact replica of apexi, with great reliability.
8. Greddy Full Auto Turbo Timer- The GReddy Full Auto Timer packs tons of features in one economical, compact unit. In addition to two standard programmable count down presets, this timer also has two Auto Timer modes, which estimate the driving RPM according to the vehicle's alternator signal and then recommends a count down time. Additional functions include a Stopwatch/Lap Time mode, and Attack mode. There is also a built in Voltmeter and Speedometer.
8. Manual Boost Controller- One of the best boost controllers on the market…
9. Synapse Missing Link Valve- you need this in order to bypass your MAP sensor..
10. Walbro 255 lph fuel pump- it is great quality and relibilty..
Like I said this includes everything except piping..i will let this go for 2000 dollars but that is very negotiable just give me an offer, shipping will be negotitated at the end of the transaction……
custom turbo kit help MXrider22 Forced Induction 2 09-14-2003 05:35 PM
Where for cheap custom turbo kits??? DJCujo69 Forced Induction 18 04-12-2003 07:44 AM
Custom turbo kits ricodemus '88 - '91 Civic | CRX | Wagon | Shuttlee 9 06-18-2002 07:33 AM
