Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-03-2003, 03:36 AM
90LShatch 90LShatch is offline
integra gsr 14 seconds et
i have a 95 gsr teg w/ 160,000 miles with dc header revolution muffler and a cheap apc intake. what i was wondering is what it will take to make me a mid to low 14 second car its all stock other than whats listed i would like to go turbo or supercharged but too expensive maybe in the long run i know i want to refresh the motor cause of the miles change pistons but if i raise the compression i can't go supercharged can I, i dont want to go to high what a good comp. ratio for all motor and maybe supercharge??? i want to get a mugen brain port/polish and maybe some skunk 2 cams and a jg eldelbrock intake manifold some good plugs and wires msd ignition. stage 3 clutch and flywheel<<< if needed. and some stickies on my 15 rims with nothing in the trunk and full interior will that make me hit low 14s with that stuff i listed and also what am i missing or need to do to hit 14 so all you tegs out there that are 14's or faster help me out thanks........CON..
Old 08-03-2003, 05:12 PM
99GSR's Avatar
99GSR 99GSR is offline
My car runs low 14's with I/H/E, Port & Polish,Skunk 2 Camshafts,JG Edelbrock Intake Manifold, and Crower Dual Valve Springs & Titanium Reyainers.
Old 08-04-2003, 02:20 AM
is that on slicks or street tires??? did you do anything to the lower part of the motor like pistons??? but also you probably dont have 160k miles which sucks!!! im gonna put some pistons in but dont know what kind i like je but maybe type r pistons are better??? what stage of camshaft do you have??? how much total do you have into the motor??? also what was your times??? high or low 14's i would love to go faster then 14's but dont want my goal to be too high so 14's seem fast!!! thanks for your help
Old 08-04-2003, 11:56 AM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
spray
Darrell
thegrumpysergeant.net
Old 08-04-2003, 12:17 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Re: integra gsr 14 seconds et
supercharger is more for low revving, high torque cars like camaros. turbocharging is for high revving lower torque cars like integras. so... you should turbocharge if you are going between turbo and super. and as far as the pistons you're going to have to pick one. you dont want high compression pistons on a turbocharger. so if i were you i'd wait on the pistons until you have the turbo unless you want to go all motor then get some 11.0:1 pistons by JE or something...
Old 08-04-2003, 12:18 PM
90gs's Avatar
my friends 91 LS with 195,000 miles on it runs 15.1 with:
intake
exhaust
reprogrammed ecu
msd plug wires
Old 08-04-2003, 04:13 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
i hit a 14.8 on stock tire pressure an my passenger seat in. take those out, i'd hit a 14.7 atleast.
really, i'd go w/ a test pipe, new cams, some nice tires an strip ur car an u'd be lookin at mid 14's rite there.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 08-04-2003, 07:22 PM
hai_IntegwaTwypeR hai_IntegwaTwypeR is offline
totally stripped '93 nissan sentra ran mid 14's totally stock....
'99 Silver Integra LS non-Vtec
Drag Turbo in the garage next to the Greddy Racing Intercooler next to the VIS CF hood making friends with the Predator Side Skirts coupled up with the shogun back and front bumpers with the Audiobahn 12" subs wanting to make love to the Optima Battery because of my JL 300/6 amp and my 1200x2 JBL. while i Sit in my cockpit adorned in Recaro Racing seats with Red and Black upholstering.
IN MY CAR: AEM Cold Air/N1 2.5" Exhaust/OBD1 Flashed Chip/Magnecors/Toda Racing Cams/Mugen Front Sway Bar/RS Limited White Wheels (Very Limited)
Ultra-High flow fuel system coming with some spines, Gears, and a torque converter. AT TURBO WOOOHOO
Old 08-05-2003, 01:33 AM
im thinking of just going supercharged cause turbo is way to expensive and needs alot of things with it. supercharge is better for day to day driving and with 6psi i can hit 13's stock with some slicks. but what all do i need before supercharging my motor with a jackson supercharger at 12psi pulleys. like lower compression pistons etc; remember that i have 160,000 miles or will that hold up stock??? thanks need much help......CON...
Old 08-05-2003, 08:51 AM
A_C_U_R_A-GSR-97 A_C_U_R_A-GSR-97 is offline
HMMMMMMM
What do you exactly mean by PORT POLISH???? Would that give you extra HP???? Just curious here
If you drive slow, STAY DA FREAKIN' OUT MY LANE!!!
1997 ACURA Integra GS-R
3" PVC Intake
Test/Straight Pipe
***SOON***
AEM v2 CAI
Random Tech Hi-Flow Cat Converter
A'PEXi N1 Series CatBack Exhaust Sys
DC Sports 4-1 header
Old 08-05-2003, 09:06 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
NO way in hell !!!
Old 08-05-2003, 09:17 PM
AF's #1 Bad Guy
Darrell
Old 08-06-2003, 12:29 AM
not dissin those cars (i/h/e WILL put u well into the 14's), but...stock...sorry man...post the slip or thas TOO tough to believe.
i hate doubting ppl, but thats saying it can run .7 lower stock jus cuz u stripped out the interior...how'd u lose the 700 lbs?
2003 Infiniti G35
Old 08-06-2003, 01:15 AM
port and polish is some machining you do to the head to make things flow quicker smoother and better that will increase hp significantly
Old 05-06-2004, 10:19 AM
laoz_gsr98 laoz_gsr98 is offline
Send a message via AIM to laoz_gsr98
i have a integra gsr wit a jacksonracing supercharger, boost 1 upgrade... and im runnin a direct port 75 shot of nos. i took it to the track once and i ran a 12.293. but i only got to run it once b4 it started to rain...atleast i got my $$ back and got to see my time
