Old 08-03-2003, 01:53 AM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Lightbulb Revell 1999 Chevy Silverado 6" Lift...again
A couple of people have PM'd me asking about the Silverado lift. I rebought the Revell Silverado kit today, and decided to make a lift, with a better explanations.
The insperation:
The kit:
The parts:
The tools:
-wire cutters
-testors glue
-grill lighter
-sand paper
-knife
The steps:
Get the lift blocks: They can be found on the sprues/trees
You will need 4 of these for the front alone.
Sand the ends smooth with 150 grit sand paper
Sand the lift block like this, you'll see why
Get upper A-Arms in place
Repeat what you just did, it should look like that^
Cut it where the knife is
Should look like that once your done
For the back of the lower A-Arm, you need another lift block. It needs to be cut at the angle you want your lift to be angles at.
Using the stock coil, cut it at the same angle as the lower a arm lift block
The spindle has to fit in that tiny gap.. lol, thats why you angle it..
This is what it looks like so far
After some adjustment it looks perfect..kinda..lol
Unfortunatley, the stock tie rod wont fit. So, with the grille lighter, you need to heat it, and bend it to the right shape. Not as easy as it seems..
The end result, for funt anyways.
Time for outback. Unfortunatley, the stock leaf springs are shaped like a sideways 7. It attaches to atop the fram instead of underneath, so you need to cut off the 7 hence making it shorter. You need some extenders:
Cutting off the "7" (blurry)
The springs with out the "7"
The extenders with lift blocks.
The end result
The very end results
Hopefully this clears stuff up
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 08-03-2003, 03:34 AM
Slipknot's Avatar
Slipknot Slipknot is offline
Send a message via AIM to Slipknot Send a message via MSN to Slipknot Send a message via Yahoo to Slipknot
holy shit did you figure this out by your self or did someone show you
Old 08-03-2003, 04:17 AM
airforceone's Avatar
airforceone airforceone is offline
Send a message via AIM to airforceone
Even better!
You should be a teacher or something! The explaination and photos were exactly what I needed, thanks!
Old 08-03-2003, 10:26 AM
i thought of it all by myself actually..
Old 08-03-2003, 11:13 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
I have to go out and buy that model again and do that. Thats so awesome. What kind of tires are you using?
Old 08-03-2003, 12:36 PM
A pair of 36" "Formula Desert Dog PCV" from AMT'd Dukes Of Hazzard Daisy Duke Jeep. It's also a popular tire from alot of MPC kits.
Old 08-03-2003, 02:06 PM
EMAXX's Avatar
Ok, thanks. Are you going to finsh the model, or are you just going to leave it now?
Old 08-03-2003, 02:15 PM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
Holy...that's some piece of art
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 08-03-2003, 06:50 PM
super glue to the rescue! Unfortunatly the fron end broke apart, so im waiting for the glue to dry.
Heres some progress... check out in the subforum for completed pics
Old 08-03-2003, 06:54 PM
EMAXX's Avatar
Looks really good so far.
Old 08-04-2003, 05:45 AM
CamaroBoyL32 CamaroBoyL32 is offline
dude you are a genious
Old 08-05-2003, 08:51 PM
I have done some extensive research, so, look for new and better parts for your off road silverado.. I really want to see someone else build one up. In the "lab" (as i like to call it) i have a 12" 2WD drive suspension lift, but this one you will actually be able to turn the wheels as in previous lifts, you hannte been able too, i have an 8" 4X4 (YES A 4X4 CONVERSION FOR YOUR 2WD TRUCK!), using transfer cases, drive shafts from the Revell civic,and a differantial housing from old rear axles. Also in the mix, i have some pre runner parts comming up, such as front skid plates and brush gaurds. And i will also have shock hoops availabe for all applications, keep an eye peeled, cause someday, their might be a 4x4 1999 Silverado here (there are know known 4X4 Chevy late model truck kits made unless you buy an AMT [which are 00P] kit and buy Perry's Resien conversion) and Maybe I can even start selling stuff.
Old 08-05-2003, 08:57 PM
EMAXX's Avatar
I'm trying to find the model at my local Wal-Mart. As soon as I do, I'm going to make the truck with a lift and etc.
Would you mind if I made a duel exahust like you did? I wanted to ask just incase.
Old 08-05-2003, 09:07 PM
go ahead, i wanna see someone else do one like mine.
Old 08-05-2003, 09:25 PM
EMAXX's Avatar
Ok, thanks dude. I'll try and find that model and I'll build it as soon as I can.
