Old 08-03-2003, 01:28 AM
93lude 93lude is offline
93 prelude h22a drop
Hi I am about to get my h22a for my 93 prelude with a f22 in it.I have a few questions befor my dad and i drop the engine in. I am getting the engine from http://www.osakajdmmotors.com/ it comes with
Motor
Transmission
Engine Wiring Harness
All required Cables
ECU
Distributor
Complete Intake Manifold
Alternator
A/C
Power Steering Pump
All Brackets and Sensors
Shiftlinkage ($75 extra)
I think al i am going to get is new motor mounts.But i want to make sure thats all i need to get. So for the people who have done a h22a swap efor please tell me what all i would need
Old 08-04-2003, 04:24 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Engine swap
I did the same with my car. It also had the pissy f22 engine, you wont know yourself after the swap. Do yourself a favour and while the engine is out do this. A cylinder leak down or bench compression test, a new clutch preferably with bigger pressure plate, split the box and check the gears and syncros for wear. Put new driveshaft seals in when you put the box back together and seal it correctly, you dont want any leaks. If you spend a day on proper preperation now, you can save yourself alot of heart ache.
Your list sounds about right so good luck.
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
