Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 08-02-2003, 08:02 PM
Barbie Barbie is offline
Exclamation Please help, 1994 Tempo idle for 8 months
I bought this Tempo from family member, good deal. However, it has been sitting through New England weather, idle for 8 months. Charged it up, lights, etc. work, but does not want to turn over at all. Any ideas? Hate to have it towed to garage.
Old 08-02-2003, 09:47 PM
pcv pcv is offline
Try giving it a boost and let the boosting car run for a good 7-8 minutes to bring the battery up to cranking power. It should at least crank. If it does not crank, replace the battery and go from there. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 08-04-2003, 08:50 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
The gas in the tank and lines is sure to have changed to lacquer by now.
How much fuel is remaining in the tank? It will have to be drained; you may be able to do this yourself by disconnecting the fuel return hose, attaching another line, and running the pump. Put the old gas in an approved container! It will still burn! Just not well enough to run an engine.
