Old 08-02-2003, 07:28 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Oil-changing tip
I may be the only person left who didn't know this trick, but today I spent two hours trying to unscrew my oil filter. I used rubber gloves, jar opener grip pads, pliers, and even tried hitting it with a hammer because I was pissed off. I called a friend and told him this bs and after calling me a dumbass he told me to hammer a screwdriver through it and pull. After getting oil in my eyeball and some long cussing, it came right off.
Old 08-02-2003, 07:37 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
why not just spend 4.50 on the adjustable oil filter wrench that connects to your socket handle?????
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-02-2003, 11:48 PM
97civichx's Avatar
97civichx 97civichx is offline
Send a message via ICQ to 97civichx Send a message via AIM to 97civichx
yeah i dont mean to make you sound stupid but crxlvr is right, thats the best way. get the oil filter wrench thingy. thats the way i do it.
97 civic hx
mod list: CAI, 17" wheels but now removed and much more to come.
not much of a list yet really
Old 08-03-2003, 12:52 AM
BullShifter's Avatar
or even purchase filter pliers. oil filter straps dont work well on honda - the filter cup that crxlvr is talking about is the best way to go. I would use large channel locks before the last resort screwdriver method.
Dont forget to replace the drain plug washer with each oil change or you will have a small annoying drip
Old 08-03-2003, 08:22 PM
Ricochet's Avatar
Banned
I buy Honda oil and a filter from the dealership every change, and the filter comes with not one, but two new washers just in case
Old 08-04-2003, 12:02 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Screw that mess, when I change the oil on my Civic, I can twist the filter right off with my bare hand! It's all about NOT tightening as tight as you can when you put a new filter on. Putting it too tight will fuXor up the rubber O-ring seal and cause leaks.
Wrenches/cups are for the weak.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 08-04-2003, 07:53 AM
Ricochet's Avatar
Banned
I rub a little bit of new oil on the o-ring to make a really good seal, then hand tighten it. By rubbing that oil, it makes it rough to get off I guess.
Old 08-04-2003, 01:56 PM
Cali Guy
Not really though. I put oil on the seal as well, which doing so is what helps keep the seal snug from leaking when you hand tighten it on, that's why you don't want to tighten it too tight.
hessemer69 on AIM
Old 08-04-2003, 06:37 PM
crxlvr's Avatar
you are only supposed to put another 1/4 turn into the filter after the gasket makes contact.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-04-2003, 08:04 PM
Cali Guy
I think I turn it 1.25 turns more than that, but I can still unscrew it off with my hand when I need to, no tools required.
hessemer69 on AIM
Old 08-04-2003, 11:15 PM
Yes lubing the seal is a good idea I usually pre-fill the filter before installing, less time w/ no oil pressure. Some cars are impossible for pre-filling the filter due to mounting posistion. If you can't pre-fill, fingering the threads with new oil is also a good idea. Dont forget to wipe down the mounting plate before installing new filter & make sure the old gasket came off when removing the old filter. Double gaskets are mess not that I did that before
There is no reason to be superman when tightening the filter, just think your gonna have to remove it next time. I use a shop rag sprayed with Fuel Injection cleaner for removal & installing - makes a nice grip - latex gloves makes a nice grip also
Old 08-05-2003, 07:26 AM
Ricochet's Avatar
Banned
Damn anybody know how many quarts a B16B takes? I put about 3 3/4 in, drove around for a couple days, and when I checked it last night there was just a little smidgen on the tip of the dipstick... Also, I checked underneath and saw no leaks.
Old 08-05-2003, 09:28 AM
i think B16 takes 4.25qts. if you are unsure on the oil amount - 4cyl start with 3.50qts - 6cyl start with 4 qts - 8 cyl start with 4.50qts. Start the engine & wait for oil pressure(few seconds) shut off engine & check oil level. If low add as needed. Its always easier to add more oil then drain .50qts.
Old 08-05-2003, 01:38 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
yeah, I do it by hand, and turn it about 3/4-1 turn after the gasket hit. last time I did myoil change, I took off the filter, oiled the gasket put it on and tightened it and knew something felt wrong but went on anyways, and then put in 4 quarts. started it to get the pressure going, only let it run like 5-10 seconds I guess, chewcked it and it wasnt even touching the dipstick, looked under the car and all my oil was on the slab. took off the filter and removed the old gasket and then proceeded tpo feel like an A$$
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 08-05-2003, 01:50 PM
Ricochet's Avatar
Banned
hmmm, I wasn't leaking oil, it turns out it was so clear I couldn't see it on the dipstick last night. Today it's on the top dot.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
