Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 08-02-2003, 01:39 PM
DB240SX DB240SX is offline
Exclamation need desperate help with leaking gas tank
Hello. My girlfriend has a 1995 Nissan 240SX that she got about 8 months ago. About 3 weeks ago the gas tank sprung a nasty leak. My brother-in-law is ass. man. at a large Nissan dealership's body shop, so we put it on the rack, checked it out and found a crack at the front right top of the tank, RIGHT by the straps.
We replaced it with a used tank and then about six hours later that night, the new used tank sprung a leak/crack in the exact same spot. Btw, pulling a tank is about 8 hours of work: you have to drop all kinds of stuff like the exhaust system and the ENTIRE rear IRS (suspension) . Also, a new tank is about $400 (if Nissan had ANY ANYWHERE in the country) and the labor is 8 hours flat rate (that's 8 x $84 of labor), just to explain why we didn't pay someone else to fix this.
Realize that I live in Phoenix, Arizona and I believe that the problem is being caused by the 115 degree heat causing air pressure to build-up in the tank.
What I need help with is: there HAS to be a system to release pressure, such as a hose going from the tank to a vapor canister which goes into something like the intake manifold. My Mustang has a system like this. Pressure WILL build-up in gas tanks in this heat.
Does anyone know of a solenoid or system that I should be looking for that's no longer relieving pressure from the tank?
TIA!
Old 09-14-2003, 08:27 PM
snake-pliskin snake-pliskin is offline
try drilling a small hole in the fuel filler cap just a lil one use an 8th size drill bit that should do the trick.
Old 09-15-2003, 12:24 AM
Re: need desperate help with leaking gas tank
This is an old thread now. It turns out that for some reason, the right strap was pinching the tank too much and causing it too crack. We have another used tank on order and won't be using that strap again.
Thanks for your help, though.
