Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-02-2003, 12:41 PM
LacMan LacMan is offline
Question Max size rim/tire for 92 Cadillac Deville w/o rubbing
im only 16 and bought a 92 cadillac deville...i wanna pimp it out a little and possibly want bigger/nicer rims...currently equipped with 205/70/15, would 20's fit? if yes would they even look good? or should i get 18's or just nice 15's? cant i get 20's with the same diameter as my 15's just with a lower profile? o yea, and how much does it cost to lower a car?
LacMan
Old 08-04-2003, 06:59 PM
Cy@tirerack Cy@tirerack is offline
20's are too big, you'll either rub or have to do extensive modification to fit. 17's are the biggest you can go.
As for lowering the car, if springs are available figure about $200-$300 for springs plus $200-$400 for installation and alignment. Neither of the spring companies we work with H&R or Eibach offer springs for your car so springs may be tough to find.
Old 07-27-2005, 03:22 AM
bishop_936 bishop_936 is offline
That is not all true. I have a 92 cadillac deville and I have 20 inch 150 spokes on it, and they fit without any rubbing. All you have to do is get air shocks all around your car and go with a 35 size low pro tire. Now the air shocks adjust to the weight in your car to keep your tires from rubbing cause a 35 low pro tire is not cheap. so it is possible, as a matter of fact, i'm thinking bout putting 22 on my car. I just need to raise it up some and go with a after market spring and with the air shocks and it can happen. So man don't let no one tell you that you can't fit something on your car.
Old 07-27-2005, 05:53 PM
CapriRacer CapriRacer is offline
Re: Max size rim/tire for 92 Cadillac Deville w/o rubbing
Sure, 20" will fit - provided you don't worry about such trivial things as overloading and tire failures.
Old 07-27-2005, 10:31 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
the load rating on many 245/35/20's is over 1500 lbs, plenty to support the ~4500 lb deville
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 08-13-2005, 10:16 PM
JayR04's Avatar
JayR04 JayR04 is offline
Send a message via AIM to JayR04
do a test fit. theres one on cardomain on 22s. if they rub you might have to use a 225/35 or 245/30 but i doubt it.
Old 08-26-2005, 05:23 AM
dazada's Avatar
dazada dazada is offline
Send a message via Yahoo to dazada
you're only sixteen and unless you have unlimited funds (ie: rich ass parents, lottery winnings, or inheiritance) you might want to stick to a smaller wheel, 16 or 17...maybe 18"...its gonna kill you when you have to put those nice little 15" stock wheels back on your ride when you cant afford the tires for those dubs.
We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything with nothing.
Old 08-26-2005, 03:48 PM
drdisque's Avatar
you can get some nice used 20's online for less than $800 w/ tires
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 08-30-2005, 12:04 AM
Houstonian Houstonian is offline
Re: Re: Max size rim/tire for 92 Cadillac Deville w/o rubbing
Where?
Old 08-31-2005, 10:12 AM
drdisque's Avatar
ebay
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 03-01-2006, 06:05 AM
retard7117 retard7117 is offline
Send a message via AIM to retard7117
NO chance.. unless u wanna get "american racing" or a brand like that ha.
And u gotta have chrome if they goin on a caddy.
I purcheased devino rims at a local tire shop. I paid $1700-$1800 for rims and tires after taxes. They told me that they will rub a tiny bit when they tested the fitment, but as long as u dont speed around curves or hit a big bump while turning, there is no problem. No reson to go fast with 20s on anyways... Show them bad boys off.
They are 245/35/20. Tires are expensive if u search online, but i went to a local tire place. (not sears or any big company that just rips u off) try to find a small company and ask for prices. I can get 245/35/20 tires for as cheap as $138 a piece. If u search online most websites are asking $350+ per tire.
My suggestin is to buy a wheel tire package to start... Its convient.
Heres an ebay link for my exact rims. http://cgi.ebay.com/ebaymotors/20-5-...ayphotohosting
hope that helps. retard7117 is my sn on aim if u got any questions. Or check out my cardomain.. members.cardomain.com/caddy7117
Old 03-01-2006, 10:28 PM
adavis912 adavis912 is offline
Send a message via AIM to adavis912
I say 20's will fit. If I had a lac. I'll buy some 14 inch or 15 inch wires on it.
1999 Ford Contour 2.5v6 se sport. Thinking about getting 3.0 engine in.
