Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 11-25-2001, 12:13 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
More sliderz
http://4crawler.cruiserpages.com/4x4...kSliderZ.shtml
Xterra4x4.com and the Xterra Offroad Webring
Old 11-25-2001, 01:06 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
At first glance, nice, and excellent price. But, those bars between the two long pieces are just going to hang your ass up on a rock big-time when one finds its way between the "rungs" of the ladder it forms. I'll pass. Not that your rocker wouldn't pretty much be toast if they weren't there though. That would have to be a pretty bad line in the first place.
Brent
Old 11-25-2001, 03:55 PM
rrdstarr's Avatar
rrdstarr rrdstarr is offline
Interesting design
But I would fill that gap that Brent was taking about. Just lay a strip of 1/4" all the way down with drainholes at the bottom.
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
Old 11-25-2001, 04:23 PM
ChuckH's Avatar
ChuckH ChuckH is offline
Am I the only one who can't see these things? The pictures come up as red X's and I can't access the website. This is the second time I've tried since Schlud posted this. Um, I want to see damnit!
ChuckH
Old 11-25-2001, 05:35 PM
XTerra Guy
Yes, covering the gaps with a plate of steel would be preferable. That would suck to get something hung up in there. These sliderz also seem to follow the "I only drop onto rocks" rule. Whereas most of the stuff I encounter seems to be offcamber slides into rocks, or where you have to pivot around the rock.
For that I still prefer the EOE's extension away from the body.
Old 11-25-2001, 05:37 PM
XTerra Guy
Maybe you should try my glasses!
Old 11-25-2001, 06:51 PM
ToeJam's Avatar
ToeJam ToeJam is offline
Send a message via Yahoo to ToeJam
Very interesting design. It basically captures the benefits of both the EOE and Calmini designs. I agree with everyone's comments, that gap between the two rails isn't good. I read everyone's posts while I waited for Schlud's pics to download (56K baby!!) and I was thinking the design had a 1-2" gap between the rails, but that looks closer to 6-8". With a smaller gap, you could get a tip of a large rock up there that would ruin your day, but with the larger space, you could get a large portion of rock up in there and ruin your weekend. If the rock was narrow enough, you could still puncher the underside of your X (See the 3rd picture Schlud posted).
If you look at the designer's website, his original design had the outer rail angle out from the rig at both ends. He said this was so the rig pushed away from the rock as the tires approached. This seems pretty smart and a good design. I wonder why they didn't continue with that feature?
Old 11-25-2001, 07:04 PM
ned946 ned946 is offline
Weight?
Maybe not an issue for most, but my X is becoming the behemoth.
One last idea (I know I've posted about this before) would be to place a hole with in the intersection of each side at the point of one of the cross braces (ie a hollow cavity throughout) before welding it together. Later, if wanted the bars could be drilled and tapped (easy to do) and act as reserve tanks for a on board air system.
Old 11-25-2001, 07:13 PM
ChuckH's Avatar
You guys are killing me! I want to know what everyone is talking about!
ChuckH
Old 11-25-2001, 07:35 PM
Just to torment Chuch a bit more.....
Schlud,
third picture from the top, do you have the truck jacked? (Hope so, otherwise you might want to crank that right torsion bar!!!)
I'm assuming you have jacked it up using a hi-lift to test it out. That was a concern I would have due to increased leverage.
Another idea I had was if one of the shops (Skid row, Calmini, EOE) would make a bolt on cross brace from one side of the frame to the other near a slider mount location. Some have commented that the Nissan frame can twist with enough force generated by jacking from the sliders. I was wondering if there was a way to reinforce the frame near a mounting location to prevent twisting?????
Old 11-25-2001, 08:40 PM
Goliath the X's Avatar
Goliath the X Goliath the X is offline
Send a message via AIM to Goliath the X Send a message via Yahoo to Goliath the X
I have highlifted off my EOE slider several time and havn't noticed any flex. I did manage to flex one side up about 3/16" into the verticle seam under the rocker but that was operatore error. I thought I was going to miss a log angled onto the trail so I didn't slow down. I popped way up and slamed down onto the slider. Slider did its job, if it wasn't there I wouldn't be opening my passenger side door anymore.
I didn't realized how often my sliders see use until I looked under them last night. They are scratched and gouged to all hell.
G o l i a t h ~~~ [email protected]
33x10.5 BFG KMs on AR-767|ARB Bumper|SR Skid Plates|EOE Sliderz|2" Body Lift|Custom Rear Tire Carrier & Bumper|
MAXC
Old 11-25-2001, 09:17 PM
ChuckH's Avatar
ChuckH
Old 11-25-2001, 09:29 PM
XTerra Guy
Schlud,
My truck is the Red one offroading.
BTW what were you smoking when you made this comment?
I do think that the ARB is very light and with regular off-road use will get very banged up (irreversibly so).
Old 11-25-2001, 10:12 PM
I was smokin' the joint of personal experience!
I do think that over the same trails, if you were to compare the Calmini to the ARB after a good year of serious off-roadin', you'll see a difference. Due to the crappy approach angle of any Xterra, hits are going to be unavoidable........I guess time will tell!
Old 11-26-2001, 12:23 AM
XTerra Guy
I saw in your other post that you were mentioning the L-brackets looking like J's. Yeah, I missed that part of abuse when thinking of the ARB I guess because I expect that part to be dinged up, and I don't usually see it that often.
The rest of my ARB has held up quite nicely despite some good tree/stump impacts, so I was thinking it pretty tough despite all the abuse it's seen.
I agree the lower triangle part is pretty thin (mostly cosmetic, the structural part is still in good shape). Thanks for passing the pipe back.
A couple of reasons I still love my EOE rock sliderz. Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 11 06-28-2002 10:09 PM
New Sliderz are on ! Xlax Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 12-31-2001 01:59 AM
JP Sliderz Stormy Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 14 11-19-2001 12:21 PM
Calmini Rock Sliderz Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 13 08-03-2001 01:35 AM
