Old 08-01-2003, 02:15 PM
daddys's Avatar
daddys daddys is offline
d16z6 question
just out of curiousity,,is this possible
if i got a d16z6 block and switched it out with my d15b2 block and used my dx intake manifold , dx exhaust manifold and dx tranny and ecu and somehow wired vtec,,,
i got a 88 civic dx ,,no mods to the engine
Old 08-01-2003, 02:45 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
not possible and it'd be a huge waste of time even if it were possible... MPFI is necessary.
SOLD!
Old 08-01-2003, 02:49 PM
91civicDXdude's Avatar
uh, wtf, it is 100% possible, although you wont get much performance gain out of it.
Old 08-01-2003, 02:58 PM
daddys's Avatar
so it would run pretty much like a d15b2 but with vtec?
Old 08-01-2003, 03:06 PM
GTA's Avatar
GTA GTA is offline
Whee..
it would starve for fuel when in vtec cause of the dpfi instead of mpfi
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-01-2003, 03:12 PM
daddys's Avatar
GTA,,i think you said you were planning on doing this swap to your dx,,,what do you plan to do , like mpfi?etc?
Old 08-01-2003, 03:18 PM
marked001's Avatar
Moderadur
yeah....you're right..dont know what I was thinking.. possible with some external switch for vtec...... but still extremely dumb and would probably do more harm than good performance wise..
SOLD!
Old 08-01-2003, 03:55 PM
GTA's Avatar
GTA GTA is offline
Whee..
i am convert my dx harness to mpfi, then using a obd0 to obd1 harness to allow me to use the p28 (sohc vtec ecu). Im usuing all z6 stuff (intake manifold, injectors, dizzy). Since i will be using the sohc vtec ecu it will control the vtec for me.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 08-01-2003, 05:50 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Thats what i did on my swap.. used all the z6 parts cut off the ends of the 3 plugs that go to the ecu and soldered them onto the new ecu plugs from the donor car, took awhile to do but it was before i knew that dropshop had the conversion harness.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
