Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 07-31-2003, 02:42 PM
Dr Greenthumb Dr Greenthumb is offline
Unhappy 325 overheating at speed
Evening All,
quick question, my 1994 325 overheats when driven hard, the car is fine under 100 mph however as soon as it gets over this it overheats (this was tested on a private road you understand !!!!) once you back off the throttle it seetles right back down.... this started after I had it flat out in fifth on the limiter ( not wise, granted, however, it must be done ) now every time i get past 120 the temp gauge flies up !!!.....
Any ideas ???
and all tested was done on private roads gov...
Cheers
Old 08-01-2003, 02:20 PM
ugly kid jon's Avatar
ugly kid jon ugly kid jon is offline
change the thermostat, if dat don't work then change waterpump, if dat don't work then change radiator
Old 08-03-2003, 05:46 PM
BMWTECH BMWTECH is offline
God, your a smart one ugly Just change the whole car and be rid of the problem j/k It sounds like the water pump is slipping. Keep in mind that it should be plastic impeller on those water pumps. I would take the water pump out and see if there is any damage to the impeller and replace it regardless.
Old 08-03-2003, 07:51 PM
I was going to tell him to change the engine next.
Old 10-17-2003, 01:13 AM
Mr.Loverman Mr.Loverman is offline
Re: 325 overheating at speed
Originally Posted by Dr Greenthumb
Evening All,
Any ideas ???
Cheers
Slow Down............
