Old 07-31-2003, 12:54 PM
myjojo myjojo is offline
90 honda hatchback SI
car was overheating........ fixed the leak at the T valve on the hose and still is getting hot...any suggestions? Thanks
Old 08-01-2003, 10:37 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I'll move this to the 88-91 civic/crx forum... You're much more likely to get a quick response in that forum anyways.
Old 08-01-2003, 10:49 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
How old is your radiator cap?
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-01-2003, 10:50 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...thermostat?
take it out..drop it in a pot of boiling water and see if it opens...
SOLD!
Old 08-01-2003, 01:16 PM
GTA's Avatar
GTA GTA is offline
Whee..
make sure you refill the coolant and bleed the system of air.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-01-2003, 05:55 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Replace the thermostat and gasket, use new coolant and bleed the system when your done that should fix it,,, however if it got to hot you might have blown the head gasket which will require rebuilding the motor.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 08-01-2003, 06:17 PM
ci5ic's Avatar
How exactly do you bleed the cooling system?
Old 08-01-2003, 06:31 PM
gunnmen01's Avatar
On the top radiator hose where it hooks to the head the will be a 12 mm bleed screw... while filling the radiator with coolant before the car is running open that bleed screw... that will allow the sir out of the top of the system...when coolant starts to come out close it off... that should take care of most of the air in the system....
gunnmen01
GTA's Avatar
GTA GTA is offline
Whee..
follow the upper radiator hos to where it connects to the engine and on that you see a bleeder valve. open valve and fill radiator with coolant. the valve will bubble out coolant, wait til its a steady flow and close it.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
