Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 07-31-2003, 07:40 AM
bigsmith bigsmith is offline
Question ABS light
The ABS light on my 1999 Mazda B3000 stayed on this morning. I drove about 100 yds and turned if off and restarted. The light went off briefly (a few seconds) and then came back on. I drove about 40 miles with the light on. I stopped for coffee (about 5 minutes) and when I restarted the light went off and stayed off.
My question is, should I have this checked right away? When I have time? or forget about it until it happens again.
Also, if anyone could explain why this might happen, I would appreciate the information.
Old 08-11-2003, 04:47 AM
xxbulovax91xx xxbulovax91xx is offline
Send a message via AIM to xxbulovax91xx
I have the same problem on my 1990 Mazda B2200. Sometimes when I start it up the ABS light will come on and stay on for maybe 30 seconds then go away. Other times it will stay on a little bit longer. And on very few occasions it stays on while I drive for like 10 minutes. I have checked all my fluid levels which caused it to come on once before and everything is okay. Also my brakes don't seem to be out of whack, everything is working fine so I'm almost thinking I have a bad connection/ground somewhere that controls that sensor. Just my thoughts.... I'd just leave it alone until something happens.
1990 Nissan 300zx Twin Turbo
Stillen Intake
B&B 2.5" Exhaust
Short Shifter
J-Spec Lighting
1990 Mazda B2200 SE-5
APC Clear Corners and Turn Signals
10" Rockford Fosgate Punch Z
2004 Mazda RX8 Shift Knob
Life doesn't get any better than this.
Old 03-23-2004, 03:47 AM
midori midori is offline
Send a message via AIM to midori
Re: ABS light
I had the same problem before, it was some air in the line right at the RABS sensor. Bled the system and no more light!
Old 09-08-2004, 06:28 PM
Missouri Missouri is offline
Re: ABS light
Replace the senor, it is located on the rear axle.
Missouri
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
'95 Town car ABS light on and hesitation olopezm Town Car 5 12-02-2010 06:30 PM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 10:15 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
