Old 07-30-2003, 11:18 PM
91dx 91dx is offline
AF Cutter
stock b16a vtec rpm engagment?
my friend thinks the vtec kicks in about 3500rpm and I said I thought it kicked out 5200rpm... which is a stock b16a vtec engaging rpm? Thanks in advance.
Old 07-30-2003, 11:23 PM
b16rex b16rex is offline
Send a message via MSN to b16rex Send a message via Yahoo to b16rex
It's definetely not 3500, i think it's between 5200-5500.
-1994 Civic coupe DX
Old 07-31-2003, 12:03 AM
AF Cutter
cool that's what I thought.. around there. Thanks
Old 07-31-2003, 12:11 AM
No problem
Old 07-31-2003, 12:19 AM
AF Cutter
hey man should I get a vtec controler or should I chip my ecu?
Old 07-31-2003, 01:37 AM
SiZ's Avatar
SiZ SiZ is offline
I'm pretty sure with the PR3 its something like 5300 or something along those lines...
Personally, I wouldn't waste money on those VTEC controllers crap. They're pretty usless unless you don't have major mods. Same goes for a chip..
Either way, I like to stay ABOVE 6000rpm anything below is just boring.
"The nympho of info, I'm fuckin' what ya heard"
Old 07-31-2003, 02:20 AM
AF Cutter
eventually I plan on doing a CRAP load to my car so maybe the vtec controler is for me? I dunno but for now i'm jus gonna run stock vtec rpm.
Old 07-31-2003, 03:38 AM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Vtec kicks in at 5500rpm, as for controllers, I say Apex-i VAFC, best way to go 'cause you get to set Vtec and control your A/F ratio.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 07-31-2003, 05:13 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Mine kicks in at 51 or 52. I know its not 5500.
Siz- those v-tec controllers help alot if you get aftermarket cams. From what i've been told that running aftermarket cams is not that effective without the v-tec controller. For STOCK motor v-tec controller is not needed.
Old 07-31-2003, 09:19 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
5400 in my SiR. VTEC controllers are a wank and ruin your torque curve unless you are changing cam profiles dramatically etc.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
d15z1 vtec-e default rpm engagement? brainstormz '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 09-04-2005 12:22 AM
stock h22a vtec 205 hp vs stock gt v8 01 stang SRV BOY Street Racing 20 03-14-2004 02:40 PM
turbo on stock h22 vtec 95 lude w/non-vtec 2.3L tran SRV BOY Forced Induction 0 03-01-2004 10:43 AM
What should I expect to run in a stock ls-vtec? And also a cr-vtec? sheemo3 Engineering/ Technical 0 09-08-2003 04:30 PM
What should I expect to run in a stock ls-vtec? And also a cr-vtec? sheemo3 Engineering/ Technical 0 09-08-2003 04:29 PM
