Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-30-2003, 05:59 PM
pratikdhora pratikdhora is offline
Send a message via AIM to pratikdhora
Brakes
Hey guys,
I was wondering if anyone had instructions on how to do the front brakes on a 1998 toyota corolla. If so could u PM me. Thanx in advance.
Old 04-17-2004, 02:19 AM
mic720 mic720 is offline
really easy..., remove the wheel, there will be probably 2 bolts holding the calliper on, remove those and slide it out of its little housing, with a little effort the pads should come out, all you have to do is and make sure to suck some fluid out of the brake fluid resvoir before you do this, is push the pistons back inside their cylinders. after that, put the new pads and any shims, or what not ( like raybestos noise solution).. or what not, or if OEM.., you'll probably need a grease for brakes and be reusing the old plate. put the calliper over the assembly, tight you're two bolts to factory specs, then you should bleed the brakes, with the little nipples near the callipers.., they have hand tools for that, you connect a little hose, and like a squirt gun, pump the lever, and it sucks out fluid to try to get rid of any air in the lines, make sure the resivoir full when the brakes are on, and then, turn the nipple counter-clock-wise to unscrew it but not all the way, then attach the hose, and suck the fluid out until there are no bubbles, do this for both callipers in the front, and make sure the resivoir is full, and put the tires back on,. and you're done
if you have any questions or input on my suggestions let me know
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
Brake Booster replacement causes brake lights to stay on, and brake power is VERY low Ultranpthing Let's get Technical! 8 09-22-2005 05:15 PM
The Brakes the Brakes the Brakes are on Fire!!! Neutrino Street Racing 14 04-24-2004 02:29 PM
Brakes, Brakes Brakes hondaman-iac Accord/TSX/Accord Hybrid 0 08-11-2002 10:08 PM
