Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-29-2003, 11:44 PM
Thepeug's Avatar
Thepeug Thepeug is offline
Quem queritis?
Send a message via AIM to Thepeug
$2000 complete turbo setup?
I used to think a complete turbo setup would cost about $3500, but I found a Greddy kit for only $2000. Would I need to inlcude anything else with that kit? Also, if I had a b18b and ran 8 psi, what kind of hp could I expect?
Peace, love, and premium octane.
Old 07-30-2003, 12:02 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I have heard about an average of 10HP per PSI. So I would say you can expect "UP TO" an 80HP increase. In reality I would expect around 5-7HP per PSI. It all really depends on how weel you tune it, on how well the compressor is matched for the engine, and on your airflow and cooling.
Old 07-30-2003, 07:55 AM
integragsr98 integragsr98 is offline
The b18b can safely handles 12lbs of boost with no problem, unlike other b-series. For $2000, i'm assuming it is either used, or without an intercooler. List what it has in the kit, we can help you out with what you might need.
xtremetuners.com
Old 07-30-2003, 10:16 AM
Accord_Zero's Avatar
Accord_Zero Accord_Zero is offline
Send a message via Yahoo to Accord_Zero
As far as PSI and power goes...I borrowed this from howstuffworks.com:
The typical boost provided by a turbocharger is 6 to 8 pounds per square inch (psi). Since normal atmospheric pressure is 14.7 psi at sea level, you can see that you are getting about 50 percent more air into the engine. Therefore, you would expect to get 50 percent more power. It's not perfectly efficient, so you might get a 30- to 40-percent improvement instead.
Old 07-30-2003, 01:11 PM
Thepeug's Avatar
Quem queritis?
Thanks, that helps. The kit includes "cast manifold, FCU, air intake, piping, hoses, oil lines, and miscellaneous hardware." So I assume I would need to get an intercooler. What about a blow-off valve and a down-pipe?
Old 07-30-2003, 01:33 PM
Dang...thats not a very complete kit for $2000...Yes intercooler is highly recommend for boosting over 8psi, even though if you are not boosting over that, you should still get one..may be a small side mount, most of the bigger one are the front mount intercoolers. So for a basic turbo setup, you also need these:
- Intercooler
- Wastegate
- Blow-Off Valve
- Downpipe
- Missing Link
To run the turbo more reliablely, you might have to do some fuel and ignition upgrades in the future. Such as, fuel pump, fuel injectors, Fuel Rail, Fuel Pressure regulator......
Get a better exhaust, the stock one would not do any good.
xtremetuners.com
Old 07-30-2003, 01:44 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
8psi expect around 190hp@wheels..
what integragsr98 said is right so far..
yea that kit doesnt provid much for 2'g i say put in the extra 1500 and get the greedy kit and you will get everything you need.
buying small parts like the ones not included can add up...
1
Shift_BOOST
97 s14
Old 07-30-2003, 08:18 PM
Thepeug's Avatar
Quem queritis?
Thanks. That's what I feared; turbo is damn expensive. Ideally, I'd like to get about 230 hp to the wheels. I can't decide if the cheaper route woud be a boosted b18 or an NA b16.
Old 07-30-2003, 08:28 PM
Thepeug's Avatar
Quem queritis?
By the way, that $2000 kit is a a Greddy kit. That's why I thought it was such a good deal, but apparently not. It was off of a site called genxracing.com.
Old 07-30-2003, 09:03 PM
PWMAN's Avatar
PWMAN PWMAN is offline
The new Edlebrock kit will be out for the B18B1 soon, get that and expect good gains. It comes with a new intake manifold with 4 additional injectors on top of your stock ones. Talk about potential, run 12 PSI (it comes with intercooler) and get a good 3'' exhaust system and I would expect somewhere around 250 WHP.
Or atleast with the stock setting of 8 PSI, and the exhaust you should see 230 no problem.
Old 07-30-2003, 10:48 PM
Thepeug's Avatar
Quem queritis?
That's awesome! I wonder how much it cost, and when it's coming out. A boosted b18 is sounding better and better.
Old 07-30-2003, 10:52 PM
Thepeug's Avatar
Quem queritis?
I just saw the ad in SCC, and it said the kit is for '96-00 SOHC VTEC Civics. Would it still work with the b18? Btw, it's $3500.
Old 07-31-2003, 06:58 AM
PWMAN's Avatar
No that one won't work. But they are coming out with one for 94-00 RS/LS/GS tegs soon.
Old 07-31-2003, 07:59 AM
yep read & learn from PWMAN he's da expert
xtremetuners.com
Old 08-01-2003, 10:12 AM
Thepeug's Avatar
Quem queritis?
Haha, thanks.
