Old 07-29-2003, 09:39 PM
riceriderjade's Avatar
riceriderjade riceriderjade is offline
For anyone who hates ZCs
I'm lookin at getting one and i want to hear everyones beefs with them, realiablity problems, problems finding parts, things like that. I don't need to hear praise for them, I just want to know all the bad things i can expect from them. Preferably personall accounts of things that happened to you. thanks a lot!
Old 07-29-2003, 09:45 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
well the main problem i'm having with mine right now is that apparently the cam angle sensor wore out and is spewing oil all over the place... working on getting another to fix that prob...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-29-2003, 10:01 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
You want the beefs, eh? Well, get ready.
They have brittle bottom ends, my first one lasted me about 1.5 months before i spun a bearing and broke a rod. grenaded the motor and cost me $$ and time to redo the swap.
Impossible to match up parts, like gaskets, bearings, sensors, etc.
No such thing as performance internals. Small differences like .1" difference on rod width keeps you from using usdm parts. it's a real pain in the A$$
you can't find cams. The only set that is supposedly out there has issues, and I have yet to hear of anyone successfully using them.
The Si and 1G Teg ECU's both run the car lean, so you have to be careful about how hard you run it, and you should definitely get an analog oil and air/fuel gauge for a ZC.
Weak oil pump gives low flow if you are going up a hill. This is one of the things that really did in my first one, I was accelerating up a hill.
Intake manny and headers don't quite match up with USDM D-series motors, so if you get a header you have to grind away at it to make it match the ports on the head.
They chronically leak oil out the head and valve cover gaskets. I can't get it to stop doing that.
There are lots of different versions of the ZC, and it's tough to tell if you got one from 1988 or 87 or 93. Most of the shops say that they are under 35K miles, and you can't really tell since there is no identifier on the block but the ZC.
The timing belt is impossible to get on right. The ZC's cam gears don't line up exactly vertical at TDC, so it is confusing to try to get the belt on, and then it is very prone to slipping to a tooth off, since the cam springs are fighting you the whole time.
The tensioners are prone to breaking. Get a spare tensioner off a twin cam prelude or teg from the junkyard before you do this swap.
There is no vacuum inlet for the purge cut solenoid, so sometimes you get a lot of gas fumes at stoplights and such.
They seem to be prone to throwing TPS codes, even if you have a good TPS. I went thru about 4.
You can't get a cam gear for it. the ones for the DOHC D16 from the teg's don't work. You have to have a set of B-series gears machined down, which is a pain and expensive.
I could go on. I've been pretty frustrated with this swap. I am about convinced that it is best to stay with usdm equivalents, and more specifically stick with b-series if you want to do any real tuning. Email me at [email protected] if you want to talk about it more.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 07-29-2003, 10:08 PM
yeah timing is def. a royal bitch... i don't by 35k miles... no way does a cam angle sensor were out like mine is in 35 thousand... with the si ecu its slower than my a6 was with a cam... i miss that engine a lot
Old 07-29-2003, 10:14 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
My only problem is stuff associated with the engine being from 92, leaking oil pan gasket (havent put a new one on yet), the oil pressure sending unit leaked, 5 min fix when you change the oil. I had to replace the coolant pipe on the back of the block because it somehow rusted, forming a tiny hole. Sure there were some issues when putting it in, it is after all a different engine then what was intended, but those were only one-time deals. ECU was no problem, because I have an SI,and it runs well enough.
As for parts, the only major things I had to replace on it are the flywheel, clutch disk, pressure plate, and the throw-out bering, I used a normal SI stuff from Honda for that.
Oh, and I have the ZC trans, and the speedometer cable doesn't want to stay in very well, I can knock it out just by fooling around under the hood.
Old 07-29-2003, 10:22 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
i know this thread is about dohc's ... but i just wanted to tell you guys that I have no problems with my SOHC ZC other than the distrubitor failing on me. Been a very reliable motor.
But yea, I think the d16z6 is one of the best swaps you can do if you wanna keep your stock mounts and use a lot of your stock stuff and not spend a lot of money. If my motor goes, I will deff be getting either a d16z6 (or if i have more money) a b18a
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 07-29-2003, 11:34 PM
wow, this really changes my mind about the zc
i'm thinking of going b16
anyone got some beefs with that to share?
Old 07-29-2003, 11:36 PM
yeha22 yeha22 is offline
i suked water into my old D16 in my CRX Si. the only reason i got a ZC was because it was cheaper to buy. i really wish that i still had the D16. it's power was much more useable. seems like the ZC has nothing down low, whereas the D16 still had something there. i havn't had it very long, so nothing big has gone wrong yet. i just think that if you are going to spend the money by choice, save up and get a B Series.
Old 07-29-2003, 11:47 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
They aren't great but stock they should hold up fine. Remember these engines are used and you are never really sure how they were treated before you got your hands on it.
Most D16A6 or A1 parts will work on it. I've never had any problem finding any parts.
Eagle makes forged rods and pistons for the ZC. I'm sure other companies do to. Plus all A1 and A6 pistons and rods should work just fine.
Delta will regrind your cams to any spec you want for $95.
Si runs lean, 1G Teg runs rich.
Never heard of such a problem.
You only have to port the header about 2mm. Not a big deal for a Dremel.
Mine has new spark plug seals and valve cover gasket and it doesn't leak at all.
All Honda engines have a date stamp on the block, its near the header.
Only one of the cams tries to fight you. Slip the belt on the exhaust gear and then on the intake one then use a wrench to move that gear up a little which also tensions it and makes it work perfect once you tension it down.
Never heard of this.
I left mine unhooked up. I've never had any problems.
Once I got a good TB I never had any problems with the TPS.
JUN makes DOHC ZC cam gears for about $300. Not a bad price for 2 of them.
I'm not saying what you are saying is wrong but everyone has different experiences and you can find lots of parts that will work if you do research.
PS FUCK THIS SERVER FOR MAKING ME TYPE ALL THIS SHIT TWICE!
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-29-2003, 11:48 PM
am i over looking a D16Z6?
Old 07-30-2003, 12:10 AM
4GZChatch's Avatar
Definitely stay away from that one. It's way weaker, and you run into a whole new batch of mounting problems etc.
I'm by no means the end-all to ZC knowledge, I'm just listing the problems that I've had with mine. It's been a real trial, and my point is that my next swap will be a B-series just for the convenience of it. it's not that much of a difference financially, just go for it!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 07-30-2003, 12:51 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
I agree with you 100%. My ZC doens't have a single problem that was mentioned here......
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 07-30-2003, 02:54 AM
SiZ's Avatar
SiZ SiZ is offline
I don't hate ZCs at all. Part of the build I had planned for my ZC had all the bolt ons, cams, and an LSD.. When I seen the cost of a set of ZC cams and realized I can get a B16 for cheaper, with an LSD tranny, and I still wouldn't be as fast as a B16, I ditched the ZC and when on to something I'm a lot more happy with. (I won't get into it)
"The nympho of info, I'm fuckin' what ya heard"
Old 07-30-2003, 04:10 AM
hahah well i think its pretty clear more people love there zc's then hate them. i'm gunna go talk to the guy i can get my swap done by and make sure he knows how to do repairs, he did a dock zc swap for a guy i know who is more than happy with what he has.
personally i'm not to concerned about performance mods, i'll just save my cash and turbo if the speed doesn't meet my desires. i'm making some half decent cash right now and mom and dad still support me.
BUT! they didn't pay for a cent of my car
Old 07-30-2003, 04:18 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
I also never had any of those problems with my zc...
I do however recommend doing some maintenence items before install...ie - timing belt/w pump and headgasket...
I don't understand all this about the zc lacking low end power. My car was incredibly fast, ESPECIALLY on hills.
And like the last post...I also will go turbo when I feel the need for extra power. I love the Zc, and its just as capable as any other honda motor that will fit the ef chassis.
There's nary an animal alive that can outrun a greased Scotsman!
Nissan Quest: Perfect minivan for people who hate minivans - Lowell Sun Automotive News Automotive News Desk 0 08-29-2006 07:50 AM
For anyone who cares Styxnpicks Car Audio 8 08-26-2002 09:59 PM
New and improved Road Logo Desktop for anyone who wants it boingo82 General 6 03-09-2002 04:58 PM
