Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-29-2003, 12:53 PM
rmb rmb is offline
Question 91 Integra not running
Could somebody help me with my integra....
Car will not start...
Check distributor cap and rotor..
Cap is burnt and found the ignition coil burn also.
Replaced cap and rotor, ign coil still will not start.
Is possible that the ignition module went bad also.
Thanks,
RMB
Old 07-31-2003, 08:01 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
what does it do when you try and star it? does it crank or does it just do nothing? are those the only parts that are bad that you know of, and did you replace them and try starting it again?
Old 08-01-2003, 04:53 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
try checking all the wires that run from ur distributor. its really common for one to jus come loose.
check ur battery? i hope so...could be a bad alternator (which would lead to a dead battery...)
if not that...then i'll have another idea...jus gotta think, an im too lazy.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 09-19-2003, 12:52 PM
Jascias Jascias is offline
Yes It is.
Yes, I have three Integras and this is one of those things that is not well known, as it boggle my mind as to what was wrong on my integra when it happen to me. I 100% think your problem is the ignition module. My friends acura did the same thing as mine and yours. Woundn't listen to me and tried a bunch of different things until he let me change the Ignition module. Guess what, it work! Another thing, Get the ignition module frome acura dealership, I can't say this enough! When this first happen to me I got mine from auto zone, went out after 2 months!! Change it this time with one from Kragen. Nope!! went out in 4 months! Got one from Acura, Guess what, Being working so far for three years. So pay the extra and get it from Acura.
not running, then running? daveid Accord/TSX/Accord Hybrid 1 02-23-2006 04:31 PM
no fuel... not running.... IF it runs it stalls tubjub M Bodies 3 09-16-2005 06:01 PM
92 Mercury Marquis running lights on all the time even when car is not running debdenis Grand Marquis 0 02-03-2005 07:30 PM
Tranny shifts fine when engine is not running but, shifts hard when engine is running CR50HC '88 - '91 Civic | CRX | Wagon | Shuttlee 6 08-01-2004 02:54 PM
Integra not running right fdreher Integra 6 10-26-2003 08:46 PM
