Old 07-29-2003, 11:24 AM
hodrodt hodrodt is offline
Question 2000 silverado drl
drl headlights always burn instead of running lights when the truck is started. Does anyone else have this problem, how can I correct it?
Old 12-11-2004, 02:13 PM
xlseeor xlseeor is offline
Mine does the same thing. I took it to the dealer and paid for a diagnostic. The dashboard sensor was good, the relay was good, so they wanted to disassemble the dash and start looking around in there. I told them that was enough and to quit before it cost me an arm and a leg. I still don't know what the problem is. Have you had any luck?
Old 02-20-2005, 01:17 PM
pies pies is offline
Re: 2000 silverado drl
push and release your emergency brake , it turns headlights off
Old 02-20-2005, 01:59 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Yur description is a little confusing to me, do you have this problem during the day , at night , or all the time. Your truck has headlights as well as seperate DRL's (day time running lights). There is a sensor on the dash at the base of the windshield in the center about the size of a pencil eraser and it is a black plastic dome. Make sure that nothing is blocking that sensor. Which lights are always on , the headlight low beams or the DRL's below the bumber in the black valance ? When your vehicle is started , no lights should come on during the day unless your truck is parked in a garage Once you put your truck into gear the DRL's should come on, these are the ones bleow the bumper in the black valance and go out once put back into park. If this is not what is happening with your truck and your headlight low beams are alyays coming on , like i said be sure that nothing is on the dash blocking that sensor and if nothing is blocking it , it is possible that there is something wrong with it.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 02-20-2005, 07:33 PM
norwood's Avatar
norwood norwood is offline
The lights below the bumper in the black valance would be the fog lights. The daytime running lights- DRL's are the clear ones just below the headlights, next to the amber parking lamps. But you are right they don't come on until the truck is put into gear. The fog lights in the bottom valance only will work when the low-beam headlights are on. The fog lights have a separate switch.
Old 02-20-2005, 09:26 PM
kenny-1907's Avatar
Thanks for clearing up my mix up norwood. Something just did not seem right as i was typing that out lol.
6" Pro Comp lift
K&N FIPK GENII
Old 02-21-2005, 02:39 AM
norwood's Avatar
No prob man. I'm just glad I have that owners manual. lol.
Old 06-28-2010, 12:41 AM
cwrong cwrong is offline
like the other poster my headlights come on whenever i turn the ign to start. what i mean by on is all lights come on like i turned the headlight switch to the "night time" position (headlights, parking lights, taillights, and lp lights). there is nothing obstructing the sensor on the dash for it to think its dark outside. how do i get it to were no lights or "drl's" are on?
Old 12-02-2010, 08:25 PM
chev01 chev01 is offline
One good test to ensure the running lights are working alright is too put a flood lamp or trouble light directed at the sensor to trick the headlights it is daytime, this of course could be used when your diagnosing in the dark.
Turn ignition on,headlights will be on,after a few seconds they will turn off,do not start vehicle, depress brake pedal and put the gear selector into drive position. Good test,when mine weren't working, I also had to replace the sockets themselves,they burned out.
Old 12-08-2010, 08:08 PM
4x4junkie 4x4junkie is offline
i have a 2000 silverado 2500 with the factory tow package, mine does the exact same thing, i also know that if you press the dome overide button three quick times all the lights will turn off, i have a trail blazer that does the exact same thing, and this is actually the second silverado that operated exactly this way, however I can not say whether this is or isnt normal operation. If it isnt, then it is surely an issue that regularly happens to these vehicles.
Old 12-10-2010, 10:32 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Sounds like either a bad sunload sensor or there is resistance somewhere in the circuit that shouldnt be there. Ill read up on this....
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 10-05-2011, 06:14 PM
Lt_295 Lt_295 is offline
I have a 2000 Silverado that had the same problem. My headlights came on instead of the DRL's. I even called a Chevy dealer and they wanted a arm and leg to even look at it. Well, as it turned out, BOTH of my DRL bulbs were burned out! I replaced them and presto, work like a champ now.
Old 11-14-2012, 05:54 PM
nineball481's Avatar
nineball481 nineball481 is offline
My truck started doing this as well. I checked the lamps...good, fuse...good, relay (swapped with a relay known to be working)...good. So I purchased a new ambient light sensor and replaced it. That fixed my issue and all is well.
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 11-15-2012, 09:17 PM
ColoradoSilverado ColoradoSilverado is offline
All my lights have been on for the past 5 year, doesn't bother me one bit.
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 12-15-2013, 09:15 AM
justme1233 justme1233 is offline
I can't get my drl to come on at all. When I turn the ignition to run the headlights come on and taillights as well. I am also experiencing a battery drain that if not driven for a day by day 2 the battery is dead. Whenever the key is out of the ignition the security light blinks. Any suggestions would be appreciated thanks.
