Old 07-29-2003, 11:19 AM
ArtemK ArtemK is offline
'95 LeSabre air vent problem
Hi All!
I have a problem similar to the following:
'89 LeSabre problems
AC only blows through defrost and floor openings, no matter what you set on the climate control panel. It acts like it's doing something (it shows that on the indicator), but nothing happens as far as direction of the air flow.
Where do I look for the solution.
I would appriciate any usefull info.
Thanks.
Old 07-29-2003, 06:33 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Sounds like you are missing vaccum to your actuators! The car defaults to floor and defrost with loss of vaccum control.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 07-29-2003, 09:01 PM
O-OK. How do I fix it then?
Is it something a normal person with a basic mechanical skills can do?
Any quick instructions? Or should I just take it to the shop? Or its' easier to forget about it?
Thanks for the answer.
Old 05-18-2004, 10:11 PM
TheFid TheFid is offline
Send a message via MSN to TheFid Send a message via Yahoo to TheFid
Anyone with the resoution details?
So does anyone have any details on how to fix the problem of a stuck actuator that results in the problem of air only blowing out of the defrost and floor vents?
