Old 07-29-2003, 01:16 AM
mjshort18 mjshort18 is offline
amp problem
hey i am having a problem with my amp( 1000 watt sony xplod, 2 12inch kicker comp vr). i keep blowing the fuses in the side of the amp and then when i replaced them the amp didn't work. it wouldn't come on. i checked all the fuses and the one under the hood but it never worked. i am also thinking about just buying a new bigger amp. if you have any suggestions on a new amp i should get or something that needs to be done to the one i have i would greatly appriciate it. thanks
Old 07-29-2003, 01:34 AM
BullShifter's Avatar
check for any loose connections
Power cable
Ground cable
Remote(turn-on)
Are the 1st place I would check.
Old 07-29-2003, 01:45 AM
i've already checked those and they are all connected properly. any other ideas?
Old 07-29-2003, 01:53 AM
Internal problem? I dunno is there fuses inside cars amps like home stereo equipment has? I never had need to take apart an amp before so i dunno
Maybe your amp or speaker fluid is low?
Who installed it? If not you take it back where it was done
Old 07-29-2003, 02:47 PM
i didn't know that they had fluid?
Old 07-29-2003, 02:48 PM
i installed it so there is no taking it back to have it worked on unless i want to spend some bucks.
Old 07-29-2003, 03:23 PM
sp3cial_bl3nd's Avatar
sp3cial_bl3nd sp3cial_bl3nd is offline
Send a message via AIM to sp3cial_bl3nd
wow..
Old 07-29-2003, 03:40 PM
tell me about the fluid since i obviosely don't know anything about it.
Old 07-29-2003, 04:13 PM
ok. and i'm really not bein a smart ass, i'm just tellin u. the fluid eliminates resonance (standing waves) and reduces reflected waves from bouncing off the metal and coming back through the cone of the speaker. it helps everything come through loud and clean...
Old 07-30-2003, 01:11 AM
Ya, you can find it next to the blinker fluid & muffler bearings . . .
I was joking with that comment about the low speaker or amp fluid
Old 07-30-2003, 10:30 AM
AirAllen01's Avatar
AirAllen01 AirAllen01 is offline
Send a message via Yahoo to AirAllen01
My cousin sorta had the same problem. He burned up the coils inside the amp. The amp had 15, but he burned 13 of them. Smell the amp and see if it's smells like something has burned up. Other than that, I have no idea.
Have you ever danced with the Devil in the pale moon light?
I'm your Huckleberry.
Don't hate the playa, hate the game.
Unreal Tournament 2004 Mexican Mafia «MM»Sternum
Visit AF's Sketching and Drawing Forum.
http://www.automotiveforums.com/vbulletin/f1155/
Old 07-30-2003, 12:21 PM
there actually is fluid in amps though...
Old 07-30-2003, 09:51 PM
Jesse Berry Jesse Berry is offline
Send a message via AIM to Jesse Berry
check and see what the impedence on the speakers are, and check how much your amp can handle. (i.e.- if your speakers are rated
@ 4 ohms, then if you parallel them you get 2 ohms. lets say your amp is rated at 1000 watts @ 4 ohms, then if you send a 2 ohm load, your amp is trying to draw 2000 watts and will more than likely burn up unless you have a protect feature on the amp. if that's the case then you'll want to wire each speaker to each channel on the amp, you'll only send out 500 watts per speaker, but that's the only way to do it.
now if your speakers are rated @ 8 ohms and your amp is rated
@ 4 ohms, then you're fine to parallel them. if you parallel a speaker with another one then you reduce your ohms by half.
always make sure that you don't have less ohms on your speakers than your amp is rated at.
Old 07-30-2003, 10:33 PM
thanks a lot. i have them bridged so you think if i just put them in there own channel then i will be ok?
Old 07-30-2003, 10:36 PM
no problem, if it doesn't work than E-mail me and i'll try to help out some more. i blew up an old amp doing that same thing
