Old 07-29-2003, 12:15 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
removing crank
ok i've got the engine on the hoist still, the tranny is off, the clutch is off... all i have left is the flywheel, crank pulley, and oil pump. the pump is no problem, but the other two kinda are.
i saw in my chilton that there is a tool to keep the flyhweel from moving, but logding itself into the flywheel teeth... where can i get one?
also, how do i remove the crank pulley? i'm guessing just make sure its all tight and break it loose, am i right?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 07-29-2003, 02:23 PM
redmanjd redmanjd is offline
their is a crank too to hold the crank still
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 07-29-2003, 06:24 PM
Jay eS Iye's Avatar
ok say what?!
Old 07-29-2003, 07:08 PM
Jay eS Iye's Avatar
ok my chilton's says i need a ring gear holder to hold the flywheel in place, anyone know where to find on of these?
Old 07-29-2003, 07:45 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Do you have an impact wrench, or know someone who has one you can borrow for a day? Those work great, you don't have to worry about the flywheel spinning, they still get the bolt out.
Old 07-29-2003, 08:46 PM
Jay eS Iye's Avatar
yes i found out how much better impact guns are oh, fyi, if you all are wondering what to get me for christmas, an air compressor and air gun would be nice
now for hte crank pulley bolt, same procedure?
Old 07-29-2003, 10:29 PM
Jay eS Iye's Avatar
ok that crank bolt is a bitch... i've used an impact at 125psi over and over and it won't budge... help someone, i need it fast...
Old 07-30-2003, 05:47 AM
im sorry it a tool to hold the crank pulley still so you can remove the flywheel and its also open so you and get your crank pully off with a socket
95 b18b
Old 07-30-2003, 09:37 AM
Jay eS Iye's Avatar
found something better... put two bolts in the flywheel location, put a tie rod separator in between the two and lodged it against teh engine stand so it wouldn't budge. got a breaker bar, and viola!
already putting it all together i was gonna get it all done this morning,but i don't have the piston ring installer, the thing that looks like a reverse set of plirs to safely stretch the rings.. gotta get that tonite (another 5 bucks, sigh)
Old 07-30-2003, 09:49 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
on my crank pulley i used 600ft/lbs and it came right off
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
