Just got a first gen CRX...
Just got a 86 or 87 crx for free
Anyways, not sure what year it is, but it's badged as an Si... I thought that the Si's had EFI, but this one doesn't appear to be fuel injected... My plans are either to make it full-on race (straight pipes, no cat, resonator, or muffler, etc.), or fix it up and sell it... or just sell it as is for a couple hundred. What kind of engine swaps can I do on this? Would prefer direct bolt-in swap... Anyways, here's some pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I guess it overheats, so I'll have to fix that...
Nice car for free
I dont think that is a real Si, check the VIN# 9th character Canada -- H='86 I='87 USA -- I='86 J='87 Model code = 8th character in the VIN I think 6 is Si 1st digit // 1=USA 2=Canada // J=Japan If its a real Si, I say restore it back to its original state. Some day that will be a collectors car. Could you imagine early CRX's & Civic's going through the barret jackson auction selling for $50,000+. That may happen 20, 30, 50 years down the road, the money then will be a cool million. If its not an Si strip it, cage it, & race it! No lights, horns, heater, radio . . . 1seat, steering wheel, shifter, & some pedals -- all lightweight body work. Now if only CRX's were RWD, how about a full S2000 RWD swap/mod? Wait how much money do you plan on spending? |
I plan to strip the interior like you suggested. I also want to do an engine swap, but I would prefer something that would be a direct bolt-in so I don't have to get mounts and all that crap. I just don't know what engines fit or are worthwhile... I don't care what the car looks like, I just want it to be fast. So, I plan on running straight pipes, no cat or muffler, and a cold-air intake setup of some sort... maybe a ram-air setup? There's some rust on the passenger side quarter panel that I'll have to cut out, and might make some fiberglass fender flares to cover that up...
nice DX! get some side draft carbs and a si head!!! then it will be a sleeper!!
What type of racing do you wanna use it for?
for drag & more tuning options you will want DOHC. I say go with a ZC DOHC.
B18A1 - bolt in(air intake clearence problem on CRX) D16 - bolt in ZC DOHC or SOHC - bolt in |
here's alittle something i wrote on another forum
hehe slap a big wing on there and soem decals that adds 10 hp right there hehe . jk i laugh at all the kids now and says doing that and not punkign otu there engines. then u get the ppl that know what they doign andf u get smoked. read a post the other day about this guy that smoked a crotch rocket in a toyota corrola. hehe the guy that saw it cs that car pull up later it has a twin turbo engine out of the supra. lol very funny to c that ppl that do things like that makes me want to meat them.
1987 honda crx si. under hood mods. 1. custom built cool air intake 2. 4/1 header. Exhaust 1. high flow cat. 2. and pace setter cat back tooned exhaust. sytem soon to come cab is being custom painted maybe. and out side is being painted soon. FOR SALE!!!!!!!!!!!!!!!!!!!!!! |
My zc with cam gears ran a 14.7 at 92 on some 13" slicks but it was my first time on the slicks an wasn't launching very agressivly.
short ram aem cam gears fuel reg an pressure gauge cm stage 1 my ls motor went 15.21 before i sent it to motor heaven,but its all with full inteior including the spare tire |
Well, I'm a bit confused...
I'm used to the 4th generation civic terminology because I've been modding my 90 Si hatchback for a while now. So, when you say ZC, is it the same ZC for 4th gens? Or is there a 3rd gen ZC engine also? Plus, jackasssi mention in his post above that a ZC would be a direct bolt-in... If that's the ZC for the 4th-gens, wouldn't that mean that a 4th gen d-series engine would bolt right in as well (since I know that the 4G ZC engine bolts right into the d-series mounts in a 4th gen)? Also, what is the clearance issue with the B18A1? Is it with the hood or the fire-wall or what? also, is the B18A1 the 86-87 teg motor? I like the idea of getting the 86-87 teg motor... is that MPFI? What tranny would I need? What ECU would I need? Anyone have any links to any engine-swap how-to's? I'm only interested in direct bolt-ins...
the 4th gens are a pain in the asss cause of the electronic dis
you can get a 86-87 teg ls or zc with the crx 1st gen an use your stock ecu or use the ls ecu 86-87. your best bet is to get a donor car cause you can swap to 4 wheel disc. ecu axle knckles axles half shaft an rear block an tranny mounts drivers eng mnt is the stock 1.5 |
Also, would I need the teg axles? And, are you saying that the stock mounts won't work except for the driver-side engine mount?
use the ls tranny out of the 86-87 teg the one the motor came with.
you do need the axles and the intermediate shaft from the 86-87 teg yyou also need the hubs from the teg86-87. the mounts from the crx you need the drivers side engine mount 86-87, andthe other 2 r from the teg 86-87. the main problem i forsee is that your car is carberated, an you have to swicth some of your fuel system an some wiring. RPR,Boman, LEW,and Gasoline Fumes may have a better discription of the things you have to do . I also would suggest RPR forum (Red Pepper Racing) but I have been unable to log on to it. I have a faq that had every thing you need but my old computer died a week ago an lost everything on it I hope this is helpin. |
yea, tom's movin and the site's been down a week now. it will be up soon though.
note, a teg motor is not a true ZC, the look similar but are not exactly the same. a 86-87 teggie's d16a1 has about 112hp where as, the true ZC had 130. the ZC your looking for from you favorite importer would be a brown top ZC. it must have the valve cover bolts on the side, if not it is a usdm d16a1. the teggie has bolts on top. i say carbs, do with what you've got! the carb setups make way more power than a d15a3 87si motor ever would. side drafts, head, header, 2.5 exsaust with a wiff of nos would push 200hp to the wheels. now that's what i'm talking about!!! |
