Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-28-2003, 10:13 PM
jessman1128 jessman1128 is offline
Question Valve cover on 2.5L engine
Hello!
I have a 1991 Oldsmobile Cutlass Calai with a 2.5L 4-cylinder engine. The valve cover has two holes in it. The one on the driver side has a 90-degree black plastic elbow in it. A hose is connected to the protuding end of the elbow and the other end of the hose runs into the air filter housing. The hole on the passenger side has an L-shaped piece plugging it. The protuding end of the L is much smaller than the side that plugs the hole. There is a mostly-inflexible hose/line running from the L piece that initially heads towards the back of the car, then cuts over towards the drive side at a 90-degree angle, then takes another 90-degree turn and plugs in somewhere either on the TBI assembly or below it.
The Haynes repair manual that I have for this vehicle is not to good at detailing info for this particular engine. I believe the hole on the drivers side is where the pcv valve is, but I cannot figure out what is on the passenger side.
Any ideas?
Thanks!
Old 08-02-2003, 08:40 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
PCV and crankcase breather!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
