Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-28-2003, 10:06 PM
somedude somedude is offline
hondata
for anyone interested in hondata. i would just like to let you know if you want to shave some serious time of your 1/4 mile. the hondata es 200 gave me 37hp to the wheel dyno'd and shaved my time from 15.9 at 87 to 15.2 @ 94 om my civ hb w/98gsr engine. as well as full throttle shifting, launch controller and rev limiter also you can program your check engine light to work as a shift light.
98 b18c1
jg edelbrock manifold
intake
4-1 header
tenzo type2 exhaust
act stage3 6puk clutch
act 8.8lbs flywheel
str cam gear
unorthadox racing pullie
RC fuel injectors
tuned with hondata
rota slipstreams 11lbs. rims w/toyo t1-s tires
FUTURE PLANS
zex 75 shot
pistons rods
skunk 2 stage3 cam shaft set
air bags
Old 07-29-2003, 11:42 AM
johnnyboy5's Avatar
johnnyboy5 johnnyboy5 is offline
Send a message via MSN to johnnyboy5
cool
i was wondering how u make ur engine light as a shift light. does it work on AT or MT or both?
I got an MT so if u can tell me that would be great.
Old 07-29-2003, 04:47 PM
there is a button that comes with hondata you can install in your dash or through your stearing wheel. if you push it once you can set your launch controller by reving your rpm up to where you would like to launch at and hold it there steady then tap the break and its set, then everytime you want to race, just hold the clutch down put it in first and give it full throttle and it wont pass the rpm youve selected. push the button 4 times and lets say you wanted to shift at 8200 you would rev up the rpm to half that (4100) then tap the break and your set. also if you ever decided to get nos there will be another button installed when you bress that just once it will do 2 things, it will re-tune your engine for nos and you can also program the hondata to spray for you, so you could set it like for example right as you shift to 2nd gear or 35mph or whatever. it will work on any honda engine auto or stick
Old 07-29-2003, 09:36 PM
00tegGsr 00tegGsr is offline
Word of advice when you get nos think twice about zex. My friend has a zex kit and dyno'd his car out and his first run with a 75 shot with a full bottle with pressure at 900 put down 58 whp then the second run was 60 whp. My NX 75 shot gave 75 whp exactly as it claimed.
Old 07-30-2003, 05:25 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: hondata
what does you timeslip look like just out of curiosity? I have seen heavier teg gsr's with i/h/e and clutch run quciker times.
Old 07-30-2003, 09:49 PM
b16rex b16rex is offline
Send a message via MSN to b16rex Send a message via Yahoo to b16rex
What's hondata?
-1994 Civic coupe DX
Old 07-31-2003, 03:27 AM
funkdaflex1 funkdaflex1 is offline
Re: Re: hondata
I was thinking the same thing that doesnt seem right. You should be atleast in the high 13's range
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 07-31-2003, 03:33 AM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
He might live in a high alttitude area. Any engine will run slower at alttitude. A car at sea level that runs low 12's may only high 12's, low 13's, or even slower at a higher alttitude. The higher the slower.
Old 07-31-2003, 10:00 AM
PWMAN's Avatar
PWMAN PWMAN is offline
Re: Re: hondata
Maybe he just doesn't have much strip experience, bad launching I guess. I wonder what his 60 ft times are.
Old 07-31-2003, 10:01 AM
PWMAN's Avatar
ZEX's kit gives 75 to the crank, NX kit is designed to give 75 to the wheels.
Old 08-01-2003, 11:21 PM
megotgsr megotgsr is offline
i went from 15.9 to 15.2 @92.5mph i live in utah (4700 feet above sea level) bone stock gsr run 17.0 with a good launch.
Old 08-04-2003, 03:11 AM
my 60' is 2.114 my 330'6.425 my 1/[email protected] my 1/4 15.2
Old 08-04-2003, 09:49 AM
gitwidit gitwidit is offline
If you already have Hondata why get a Zex kit? Hondata now offers nitrous controls. The program pulls timing and adds fuel for you. There are inputs as far as rmp on/off speed on, engine load, etc.. Very cool program that is a simple software patch if you have the S-series of Hondata. The patch is free from your Hondata Dealer.
95 EG
JRSC@10psi
Hondta S200B
Hondata Nitrous Controls
251whp
227tq
13.3@105mph
Old 08-04-2003, 12:45 PM
boosted331 boosted331 is offline
Yep, I was about to say that. Correct me if I'm wrong, but I think ZEX kits add fuel by bumping fuel pressure a pre-set amount, which is a pretty crude way to do things. You can make your own nitrous kit cheaper, all you need is a bottle (heater + blanket helps a TON) some lines for the nitrous, the solenoid(s) and a nozzle + jets, then set everything up with hondata to add the fuel.
Old 08-04-2003, 06:23 PM
SleeperCivic SleeperCivic is offline
Damb bro, my 60' is a 2.25 and I run a 14.0. What's the problem??
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
