Old 07-28-2003, 03:55 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Uniwiper
What would it take to go back to normal wipers from the uniwiper? Is it something that's hard to do? What's needed, etc
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 07-28-2003, 06:15 PM
JDM 4g4D's Avatar
JDM 4g4D JDM 4g4D is offline
Send a message via AIM to JDM 4g4D
Wipers Removed fot weight reduction.
nah, jus kidding, i took mine off cuz i think the car looks cleaner without them.
Winshield Rain-X-affied.
200whp ALLMOTOR CLUB
ALLMOTOR.NET
Car Photos
Old 07-28-2003, 06:26 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
All you need is a 10mm wrench and the other wiper, then all you do is losen and adjust the other one to where it just covers the passenger side like it is suppose to. It is very simple, it shouldn't take you more then 5 or 10 min to figure it out.
KoRnSaQ
Old 07-28-2003, 10:37 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
Why, trying to get your car into Max Power???
LOL, just kidding.....Just use the longer wiper on the other side.
There's nary an animal alive that can outrun a greased Scotsman!
Old 07-28-2003, 11:40 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Basically, the wipers are held on by a spline post, so in order to convert from a uniwiper to a regular setup, just remove the 10mm nuts from the wiper posts, pull the uniwiper off, then put it back on at the correct angle. The splines will keep it lined up. Then just add the other wiper at the same angle, put the nuts back on and you're good to go. Don't tighten the nuts tooo hard though.
Old 07-29-2003, 12:06 AM
T-Mo's Avatar
Thanks alot folks. I knew that I could count on you all for info.
'93 Honda Civic EJ2
Anyone else sportin the uniwiper? Melt Accord/TSX/Accord Hybrid 8 10-30-2002 05:43 AM
