Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-28-2003, 01:08 AM
Jeff726 Jeff726 is offline
Red face Electrical system and power windows
I know there's probably an obvious answer out there, but the driver's power window has quit working but all the others work fine. Why I don't know. It is the one that goes down on its own. How do I fix it?
And also, the dashboard lights seem to have gone out. I can hardly see the fuel gauge or temperature gauge at night. What do I do there?
Old 01-31-2004, 10:27 PM
mmichalak mmichalak is offline
for your windows, i would say that it could either be your master switch, which is the drivers side switch that controls all the windows, the motor, or the wiring from the switch to the motor, u can pull the door panel off, and actually apply power directly to the motor, from a car battery and two little leads if u are careful to see if it operates properly. u can hook the power up either way because it will only control which direction the motor winds the window up or down, if the motor operates check for any visible damage to harnesses or connectors, if no luck id say u should replace the master switch.
Old 07-31-2004, 03:17 PM
00chris00 00chris00 is offline
Re: Electrical system and power windows
i have the same problem but its the other three that wont work.the only one that works is the main one,and i just went to buy a new master switch.
Old 07-31-2004, 06:50 PM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
for the windows i would guess that the motor died.
for the dash lights, there should be a vertical knob sort of thing just left of the steering wheel (don't know the right word for it). anyways, turn that all the way up and that should fix that problem
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
