Old 07-27-2003, 10:10 AM
hdroadking hdroadking is offline
Question 93 4.6 CPI Problems
I had a 93 S-10 Blazer with a vortec CPI 4.3 lock up recently. Upon pulling the plugs it was discovered that the #4 cylinder was filled with gas ( so much so it ran from the spark plug hole in a stream ). When the motor is turned over with out the plugs gas shoots out the spark plug hole in a very heavy spray. This is occuring only on the #4 cylinder and not on any others. What would cause the cylinder to flood like this? It is only the #4 cylinder, all others are fine.
Old 07-30-2003, 04:18 AM
cobra1 cobra1 is offline
the poppet valve to that cylinder is broken, or something else in the CPI injector assembly is. you'll need to replace the CPI injector assembly.
Old 08-17-2003, 05:01 PM
Rob_0126 Rob_0126 is offline
Send a message via Yahoo to Rob_0126
Heres a link to a CPI explaination and it's problems/solutions.
http://forums.s-series.org/viewtopic.php?t=2278
Robert
"Life is great, when you got a V8!"
1997 4.6 tach problems segrandam F Series 2 09-04-2008 07:40 AM
97 f150 4.6 missfire problems 97wagonlx F Series 6 04-06-2008 05:32 PM
2000 f-150 4.6 injector problem yorddog F Series 4 11-29-2006 09:47 PM
94 4.6 stalling problem kgriggs75 Thunderbird 3 05-27-2006 02:29 AM
'99 4.6 Eng problems H8nFord Expedition 3 01-20-2005 04:52 PM
