Old 07-26-2003, 04:35 PM
Max-97CivicEx Max-97CivicEx is offline
Question 97 EX Stock radio dead???
After being re-installed, my stock honda radio is dead. No signs of life. Any ideas?
Here's the actual story:
I had an aftermarket radio put in long time ago, but since the keyless entry is built into the stock radio, the installer put in a special harness that allowed the original stereo to stay connected and powered behind the dash. Everything worked fine untill a few days ago someone broke into my car and stole the aftermarket radio (sucks, but that's life)
They took the radio and cut the wires where they connected to the splitter harness (why not just unplug them is beyond me, but...). The harness was left intact and they left the stock stereo. However after that the remote stopped working. So I figure untill I get a replacement deck, I would use the stock radio. However after I got it out from behind the dash and installed it proper, it is dead -no lights, no nothing.
I checked the fuses, they seem to be fine. Checked voltage on the harness, there is 4.3v on the backup lead all the time and about 12v on ACC when the car is on . Sounds like power is ok.
I thought maybe they shorted something out when they cut the cables, but I looked at the radio and there seems to be no visible signs of damage.
I figured maybe it's the security code issue, but from a quick search it
seems that when it wants the code, it powers on and asks for it - so it is
probably not that.
I am at a loss. Any ideas?
I am thinking of giving up and getting a new deck and an alarm system that has it's own keyless entry in it, but I would prefer to keep the costs down, money is definately an object.
Also, there are 3 harnesses in the back, one is radio (speakers+power) one is "security" (I assume this is keyless entry and stuff. What is the third one? Also, is there a site that lists pinouts for those harnesses?
Thanks a bunch,
-M
Old 07-27-2003, 01:27 AM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
try emailing crutchfield.com, they have really experienced guys that should be able to help you out.
Old 07-27-2003, 01:49 AM
Actually turned out to be a bad fuse. I forgot that there are fuses under the hood and that while the main radio fuse is inside the car, the backup power fuse is under the hood. Replacing the fuse fixed it.
Thanks.
-M
