Go Back   Automotive Forums Car Chat > Eagle > Premier
Old 07-26-2003, 01:07 PM
kambalaman kambalaman is offline
Question 90 eagle premier electrical
This car was on it's way to the boneyard,when I took it off the owners hands for free.The engine,trans and air work good.The windows work here and there.I replaced master control from boneyard with same results.They are strong when they work.The ventilation fan works only on high speed.Thanks in advance and nice site!
Old 10-30-2003, 07:49 PM
ifehr_2000 ifehr_2000 is offline
blower fan
Did you ever fix the blower fan? because mine does the same thing.
Old 07-10-2004, 11:27 PM
driveway's Avatar
driveway driveway is offline
Send a message via Yahoo to driveway
Re: 90 eagle premier electrical
the blower problem is for sure the resistor under the pass side dash and conected to the heater box with two screws and will be next to the blower motor. I promise you that is the problem
Old 09-21-2004, 05:12 PM
wilkin250r wilkin250r is offline
Is this a common problem? Mine does the same thing, it only works on "High". Actually, it USED TO only work on high, now it doesn't work at all.
What other common problems are there? All my selections for air controls work, but they are not illuminated, so it's impossible to know what the settings are at night. Common problem with an easy fix?
Old 09-22-2004, 01:34 AM
driveway's Avatar
yep its a common problem with general motors vehicles as well, mostly older stuff. but it is a cheap easy fix that anyone with a small socket set can do in less than 10 minutes. as far as the climate controls lighting up I would check fuses and bulbs first, I have seen lots of people spend way too much for a few hours of labor charges at a dealer just to find out it was a fuse or a bulb. if those are good then I would start checking connections and wiring. mine used to not work and it was a loose conector in the steering column, tightened it up and it has worked great ever since.
