Old 07-26-2003, 09:45 AM
drcoulson drcoulson is offline
Unhappy Ford Escort - Air Bag warning codes
My 1996 Ford Escort is flashing the air-bag warning light in this sequence:
Flash-Flash-Flash-Flash-Pause....
Does this mean anything to anybody?
Thanks
Desperate Dave
Old 07-26-2003, 10:57 AM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
Your airbag is defective, and you need to get it serviced right away. If you get in a wreck, it might not deploy right, or might not even deploy.
Old 09-04-2003, 11:53 AM
catbum catbum is offline
Could be a factory defect. I got a recall notice from Ford about the airbag sensor on my 97 Escort.
Old 05-17-2004, 01:17 PM
Discworld Discworld is offline
Air bag light
My air bag light on my 96 Escort has just started flashing too. Will it cost much to rectify????
Old 05-17-2004, 05:49 PM
Motorman Motorman is offline
Re: Ford Escort - Air Bag warning codes
Most air bag problems on escorts betweet 95 & 98 are caused by the following.
If the vehicle has seat belt pretenioners fitted you can identify by looking under the seat. if there are to wires joining to the seat belt stalk under the seat the connetor block normally right on the underneath of the seat is normally the trouble. Cut each wire one at a time & rejoin with butt connetors even though you can proberly see nothing wrong with the connector. The terminals suffer from oxidiation.
If you are unsure about doing this yourself your local garage should be able to perform this at a minimal cost.
Old 12-15-2005, 05:25 PM
bikertec bikertec is offline
Re: Re: Ford Escort - Air Bag warning codes
Do you mean cut the cables and connect them to each other bypassing the plug.
Cheers Mick
