| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
ghost flames
Here's my attempt at ghost flames. I used gloss aluminum (tamiya) and pearl white (craft paint). This was my first try and I think the results were pretty good.
Next time, I'd sand the where the flames were masked a little better. Maybe put another coat of pearl white on to hide the flames more. A nice thick clear coat would have been nice too. The reason I didn't do this time is because this was only a test, and the pearl white cracked. At certain angles, the flames are almost invisible. |
At other angels, the flames are clearly visible. Let me know what you guys think.
Shockingly good results, did you use the tutorial here in the boards, or just another technique???
Olivier |
Very Nice!!!!
if your ever going to use dupli-color mirage paint, spray on the semi-gloss base coat, and after that dries, paint on the flames using flat black, then apply so many coats of the mirage paint. I havent tried it, but i think it might work.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
Yeah, I pretty much followed the tutorial, except that I painted the flames body color after removing the masks.
Looks really good
-Pille-
Caution - Driver Legally Blonde! |
The flames look great. I'm planning on trying this myself one day. I really like the colors you chose. It's a winner....
Murray |
That looks awesome!
Your life is the sum of a remainder of an unbalanced equation inherent to the programming of the matrix. You are the eventuality of an anomaly, which despite my sincerest efforts I have been unable to eliminate from what is otherwise a harmony of mathematical precision. While it remains a burden assiduously avoided, it is not unexpected, and thus not beyond a measure of control. Which has led you, inexorably, here. |
kicks a$$!!!!!!!!!!!!!!!!!!!!!!!!!!
Erotic, Exotic, & a little Psychotic. Sex is like air, its only important if you aren't getting any. |
