Old 07-25-2003, 06:08 PM
blade34609's Avatar
blade34609 blade34609 is offline
MPFI Wiring Conversion Prob....
Hi,
I just got done takin my DX harness and modifying it.
I extended the wires that had to be extended.
plugged in alternator, fuel injection plugs, everything pretty much fits right. Except when I tried to plug on of the 2 plugs that go to distributor.
One of the 2 prong plugs fits perfectly but the 6 prong doesnt fit correctly the SI one has 7 prongs.
The DX has 6.
Should I cut the SI one out and replace it with the DX one?
Doesnt one of them have 7 and the other 6 so I dont know what to do yet?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 07-25-2003, 09:18 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
someone correct me if i'm wrong, but i believe u need the Si Dizzy!
Old 07-25-2003, 09:49 PM
blade34609's Avatar
I do have a SI distributor....
The problem is plugging the DX harness into it?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 07-26-2003, 12:09 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Yes the DX has a 6 pin plug with 5 wires going into it, and the Si one has a 7 pin plug with 7 wires. The extra wires on the Si one is for the cylinder position sensor.
Do you have the Si plug also? If so all you need to do is depin the wires from the DX plug and plug them into the Si plug and you are good to go.
If you don't have the Si plug I would ghetto rig it until you can get one, don't cut those wires, keep them intact until you can get the proper plug, it will run better like that.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-26-2003, 12:50 AM
blade34609's Avatar
Ok,
Since I am a big hurry to get this car running can I just cut the Si plug and DX plug and just color match the wires, solder and heatshirnk them.
So I would have the 6 wires connected. The 7th wire would come out of the SI ECU and go into the Si distributor. The colors match from the DX to SI distributor correct?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 07-26-2003, 01:09 AM
I think the main 5 wire colors will all be the same. Then you should have wires coming from C1 and C2 which will go into the cylinder position sensor spots. If I were you I would not cut anything, you will regret it.
http://www.hondaautomotiveparts.com/...y5=DISTRIBUTOR
#12 is the wire harness assembly, however I think you will need the other end to plug into it I guess. Try and find an Si plug at a junkyard, or any MPFI SOHC Honda engine should have a similar plug. Or perhaps if you can find a 2 hole plug you could just use that for a CPS wires and you wouldn't have to cut anything.
Old 07-26-2003, 01:15 AM
blade34609's Avatar
Ok, i guess i will have to find one.
So your saying even if I solder and hearshrink the wires together it still could come loose? I'm only gonna hopefully have to do this once as this is my only engine swap for this car.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 07-26-2003, 01:18 AM
No it would be fine if you solder and heat shrink them. But what happens when you need to replace the Distributor, you can't just unplug it and take it out, you would need to cut those wires and that is a hassle. Doing it right the first time will save you a headache in the future. Plus cut up wiring looks sloppy, I like the OEM look.
