Old 07-24-2003, 10:23 PM
Sulsa Sulsa is offline
Which Valve Angle to grind
I'm building a GSR motor slightly stroked with an LS crank Eagle rods, and Endyne high compression pistons. Compression will be about 12-1. I have portflow Inner springs and retainers and ITR outer springs (all come with their kit). I'm debating on whether to use aftermarket SS valves or stock ITR valves. I'll be using a stock GSR intake manifold and stock throttle body with a 2.5" cold air intake. I'll have a 4-2-1 header but the rest of the exhaust system will be stock.
I'm getting a 3-angle vavle job while the engine is at the machine shop, so what angles should I have the vales ground to for this setup? Anyone with a flowbench know what works well? Thanks for any advice you can offer in advance.
94 Integra LS
Engine is in the car!
Installed parts
GSR block/head, ARP head studs, eagle rods, Endyn pistons/rings, King bearings, REV stainless valves, Portlfow springs &Tit. retainers, BBK 70mm Throttle body, RC 310cc Injectors, Aerospeed plug wires, generic 2.75" CAI, Civic SI crank pulley, 130amp alternator, Hondata S300 in P72 ECU
01 GSR shocks/springs, 17" Enkei Zenkei's, Homemade Black ABS trunk floor
Mods: Removed AC system, routed Coolant Outside Intake Mani
Old 07-25-2003, 06:49 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
not sure of exact numbers, but the machine shop should have some specs as to what he will cut them too.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-26-2003, 02:20 AM
I'm looking for specific angles. I'm sure he can just do the standard 60, 45, 30 degree cut, but a guy with a flowbench once told me that altering the angles can gain you a few horse depending on what else you've done to the motor. Whadda I know? He may have been on the crack pipe.
Thanks
94 Integra LS
Installed parts
98 Stratus Grinding Noise pcjunkie7 Stratus 4 06-22-2009 07:21 AM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
Front end grinding when turning and braking rlb5390 Alero 5 02-11-2009 10:19 PM
Which valve is the intake valve? plaser007 General Discussion 1 08-29-2007 09:55 PM
