Old 07-24-2003, 07:05 PM
h22a1/Civic/DX h22a1/Civic/DX is offline
Question H22a Swap Question?
I'm trying to find as much info on swaping a 96 h22a1 into 94 civic coupe. Firts off I need to get my V-tec working (maybe I'm dumb, but i don't even know were to locait my V-Tec solenoid), I have had no luck finding any helpful info on this. Second, I don't Know every thing it needs to pass smog (sensor wise). Also I have purchased a HCP mount kit, and was woundering were the best place would be to re-weld the passinger side mount, since the uni-body is so thin. If any body could give me any info on any of this. It would be great.
Old 08-03-2003, 01:19 PM
SLEEPERACCORD SLEEPERACCORD is offline
A SIMPLE WAY TO FIND OUT IF YOUR VTEC IS WORKING IS TAKE THE CAR ON A DRIVE MAKE SURE AT 30MPH YOU ARE IN THIRD GEAR AND FLOOR IT LISTEN TO THE SOUND OF THE INTAKE/EXHAUST THE CAR WILL BUILD UP SPEED KINDA SLOW BUT AT 4K/5K YOU WILL KET A BOOST IN POWER IF THAT HAPPENS YOUR VTEC WORKS.DO IT ABOUT 2-3 TIMES.
01" ACCORD PERFORMANCE MODS:
JDM H22A MOTOR SWAP
EIBACH PROLINE SPRINGS
DC SPORT SHORT THROW SHIFTER
GReddy EVO CATBACK EXHAUST
O15 18"WHEELS NITTO 450
REV HARD T3/T4 TURBO WITH .54 TRIM
PWR 31X11X3 INTERCOOLER
ADJUSTABLE FMU 12:1-14:1 RATIO
550cc INJECTORS
VAFC
MANUAL BOOST CONTROLLER
GReddy TURBO TIMMER
AEM CAM GEARS
AEM UNDERDRIVE PULLYES
ACT EXTREAM CLUTCH/PRESSURE PLATE
ADDED 1 EXTRA FUEL PUMP(INLINE)
BOOST GAUGE
EGT GAUGE
AIR/FUEL RATIO GAUGE
TURBO-XS RFL BLOW OFF VALVE
BFG DRAG RADIALS 225/50/15(2)
FUTURE PLANS:
FULL BOTTOM/TOP END BUILD UP
AM 8PSI NOW.
Old 08-04-2003, 04:09 AM
afroeman afroeman is offline
Send a message via AIM to afroeman Send a message via Yahoo to afroeman
Alright man...First off, to see if VTEC is working go to a stop light and start as you normally would if you were NOT racing and listen for the exhaust/intake to whine a little bit once you get to about 5000 rpms, if it does then you're VTEC is absolutely fine. if not then take it to a Honda Specialist and see if he can check out the ECU and see if that's the problem. about smog, with an H22A mounting into a D15 engine compartment you shouldn't have any problems with smog. Just make sure that the Exhaust ports connect ok with the possibly different port setup of the H22. Otherwise you shouldn't have any difficulty besides just getting new motor mounts. About the passenger seat bolt...not sure exactly but you might just try a weld shop or you could even possibly get it done at a muffler shop because its some easy welding. Good Luck with the swap and remind me NOT to race you if i ever see you.
Old 08-04-2003, 08:21 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Check out the Sept 2003 Issue of Hot Compacts and Imports (HCI). The Cover Car is a 725 HP Street Legal Turbo H22 in a 5th gen civic hatch. It'd built by Rage Performance Onwer Jason Whitfield and his crew, with the help of Kurt Gordon at KG Racing. T=It mioght interest you since you said you want all the info you can on a H22 swap into a civic before yuo start. It has pages of informance dedicated to his 725 hp EG Hatch H22 build-up. Pages 26-60, or 34 pages worth. It's worth a look at least. In nothing else, it's a good read, but it might interest you since you are interested in a H22 for your 5th gen 94 coupe. I have inof on the actually swap that would help you, but It's not with me right now, it's at home. If I remember I'll post it once I find it if you want. Good Luck.
www.rageimports.com (877-4RAGE-00)
www.kgracing.com (714-841-8990)
Old 08-05-2003, 06:56 PM
Hey thanks for all the info, but I pretty much knew that part of it. What I ment was electrical asspects. Also i was wondering if any one had any pics of the tranny mount (passenger side) after it been re-welded.
dose any one want to race?
H22a swap questions... GSXBMX JDM Motor & Parts info/chat 6 07-26-2007 06:59 PM
H22a swap questions 97HCiViC Let's get Technical! 0 07-09-2004 07:41 PM
h22a swap question? h22a1/Civic/DX '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 07-24-2003 06:41 PM
Civic h22a swap question o0cmc0o Engineering/ Technical 2 09-16-2002 10:10 PM
H22A Swap Question wagsaccordsir Engineering/ Technical 1 07-02-2002 09:52 PM
