Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-24-2003, 04:14 PM
dingo39 dingo39 is offline
4"drop
i just stuck some new coilovers on my car, right now its settling down about 3 inches off the ground, i have about a 4 inch drop on the front and same on the back, my question is, is there a camber kit that will work for cars that low??? i dont want to leave it like that for too long cuz ill wear out my tires, but i like it that low, so i really dont want to lift it much, sum1 help me pls
Old 07-24-2003, 05:25 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
I can't remember where I found this, but it is a way the meaure the degree of camber you have. Then you can look on the net for a kit that will give you enough adjustment. Usually the kits will say +-3.0degrees or whatever.
There are all kinds of fancy-smancy camber measuring devices. But you can do it quite accurately with stuff every garage should already have: a ruler and a square (that steel 'L' shaped thingie.)
Put the short side of the square flat on the ground (park on a flat surface). And push the other side up against the tire. If the square touches both sidewalls, then you have 0 camber; if it only touches the top sidewall, you have positive camber; and if it only touches the bottom sidewall, you have negative camber.
Now have a friend (or a couple of bricks) hold the square in place while you go find the ruler. Use the ruler to estimate where on the square the center of the wheel is - mark this point with a pencil or some tape. Now measure 7" above this point and mark it too - now measure the distance between the edge of the wheel and this point on the square. Make sure to hold the ruler parallel to the ground (maybe even use a bubble level). Record this value. Now, measure 7" below that center point, mark it, and measure the distance to the wheel again.
Now subtract those two measurements and multiply the result by four - this is your camber in degrees. How easy is that?
Example: The upper measurement is 13/16", and the lower measurement is 1/2". Since 13/16 > 1/2, the camber is negative.
13/16" - 1/2" = 5/16" difference.
5/16 * 4 = 20/16 = 1 and 1/4 degrees of negative camber.
This is usually easier to do if you cut out a round piece of plywood to hold against the wheel - then you can just measure the distance to the square between any two points that are 14" vertically apart, and you don't have to worry about centering the square on the wheel.
Could you explain how the heck you came up with that and how do we convert that to the Metric system for the Non-US'ers???
The actual equation would be:
angle = arctan( h / l )
where h = the difference between the two measurements
and l = the vertical distance between the two measurements.
We used 1/4" = 1 degree because it's simple. Then we picked 14" because it just so happens that arctan (1/4" / 14") = 1 degree. As long as h<<l, the tangent function is reasonably linear; so we can make the approximation of just saying that:
angle = 4 * h (in inches)
To do this in metric, we need to just pick a h to represent one degree, and make sure that the required l is within reason.
If we wanted to pick 5mm for h, then l would be 286 mm.
If we wanted to pick 10mm for h, then l would be 573mm.
That's probably the best: Measure two points 57 cm vertically apart, and you get one degree of camber for every one centimeter of difference between the measurements. angle = h (in cm).
