Old 07-24-2003, 12:37 PM
ChumleyEX's Avatar
ChumleyEX ChumleyEX is offline
Send a message via AIM to ChumleyEX
Help me go faster
Ok here is what I have and what I plan to get. .I have a 98 civic EX
I have
Short RAM intake
Catback Thermal 2 1/4" exhaust
I'm getting
Header ( what is best? )
Cam gear ( Anything I need to know? )
Pullies ( I've seen diffrent pullies out there, what will give me more HP )
?????? ( what else should I get to speed things up a bit like a chip or something electronic )
I am thinking about getting the cold air intake. What advantage would it give me over my short RAM. I actually see the cold air collecting more dirt and things.
Thanks for your time
And Knowing is half the Battle
Old 07-24-2003, 04:24 PM
strodda strodda is offline
first, id say yes to the cai. but keep the shortram too, this way you can switch them in the winter if you wanted to. you can get a name brand intake and spend a couple hundred... or get one from checkpoint auto. under $100 and comes with a carb sticker. i just bought one and it works just the same. and it sounds alot deeper than the aem shortram i had.
header: dc sports 4-1
camgears: skunk2 or str pro(dont get aem)
pulleys: aem tru-power
you could also get an apex controller, thatll make vtec engagement and air/fuel ratios adjustable. and of course get it tuned after youre done.
guess it all depends on how much money you want to spend.
Old 07-29-2003, 05:32 PM
somedude somedude is offline
3'short air ram give you more hp and alot better off the line over cold air intake cold str cam gear are great they have 5 bolts the skunk2 have 6 and aem has 3. the crank shaft pullie needs to be the small and lite the smallest and lightest one out there is unorthadox racing. you should get any header you want as long as its 4-1 vibrantperformance.com has some nice headers.
Old 08-02-2003, 01:52 AM
ah789454 ah789454 is offline
what are cam gears, pullies
i just read that some guy wanted to change his cam gears.
can some one tell me wot they are and how do they make the car go better.
i thought its better just to get new racing cams
and wot are pullies??
Old 08-02-2003, 05:52 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
But these "hot-air-intakes" will suck up the hot air from the engine bay and that will actually hurt the performance of the engine!! Thatīs why most people get a CAI, Ice-Box,.....
Old 08-02-2003, 08:18 PM
SLEEPERACCORD SLEEPERACCORD is offline
WHAT KIND OF DRIVING ARE YOU DOING?4-1 HEADER SOUNDS GOOD BUT WILL TAKE AWAY FROM YOUR BOTTOM END POWER 4-2-1 WILL GIVE YOU BETTER MID RANGE POWER ALL THE WAY TO RED LINE.I THINK YOU SHOULD GO WITH 4-2-1 HEADER.GET A COLD AIR INTAKE
COLDER AIR IS MORE DENSE AND WILL RESULT IN MORE POWER.THE CAT BACK EXHAUST IS A GOOD CHOICE I LIKE THE GREDDY EVO NOT TOO LOUD(98DB) AND LOOKS WICKED ALONG WITH GOOD POWER GAINS AS WELL.BUT IF YOU LIKE LOUD EXHAUST THEN THE N1 IS WHAT YOU WANT.ALL THE UNDERDRIVE PULLEYS DO THE SAME THING
THEY JUST FREE UP POWER THEY DONT GIVE YOU POWER.THE ONE THAT FREE UP THE MOST POWER IS THE CRANK PULLY.I WOULD SAY GET A VAFC BUT AT THIS POINT IS NO USE TO YOU.I THINK THE NEXT THING YOU SHOULD DO IS LOWER IT A LITTLE BIT.
01" ACCORD PERFORMANCE MODS:
JDM H22A MOTOR SWAP
EIBACH PROLINE SPRINGS
DC SPORT SHORT THROW SHIFTER
GReddy EVO CATBACK EXHAUST
O15 18"WHEELS NITTO 450
REV HARD T3/T4 TURBO WITH .54 TRIM
PWR 31X11X3 INTERCOOLER
ADJUSTABLE FMU 12:1-14:1 RATIO
550cc INJECTORS
VAFC
MANUAL BOOST CONTROLLER
GReddy TURBO TIMMER
AEM CAM GEARS
AEM UNDERDRIVE PULLYES
ACT EXTREAM CLUTCH/PRESSURE PLATE
ADDED 1 EXTRA FUEL PUMP(INLINE)
BOOST GAUGE
EGT GAUGE
AIR/FUEL RATIO GAUGE
TURBO-XS RFL BLOW OFF VALVE
BFG DRAG RADIALS 225/50/15(2)
FUTURE PLANS:
FULL BOTTOM/TOP END BUILD UP
AM 8PSI NOW.
Old 08-03-2003, 02:59 AM
S13GTR S13GTR is offline
after spending a couple grand and not going much faster you will be sorry you didnt do a swap.
Old 08-03-2003, 08:32 AM
S13gtr is right.I learned the hard way i spent at least $2000.00 in bolt-ons and $500.00 on a NOS single fogger kit took it to the track and only ran a 14.67.and blow the engine racing a camaro.look at your options what kind of power are you looking for?what are the benifits of a SOHC-vs DOHC how much do you plan on spending?shit like that you gotta look into.then look for a good shop.some people look at the price over the quality and others look at the quality over the price.then when you find a shop go there off and on for about 2 weeks and just talk to the guys feel them out see what kind of service they provide you.look at how they keep the shop( a clean shop usually does clean work)
JDM H22A MOTOR SWAP
550cc INJECTORS
VAFC
GReddy TURBO TIMMER
AEM CAM GEARS
BOOST GAUGE
EGT GAUGE
FUTURE PLANS:
AM 8PSI NOW.
Old 08-05-2003, 09:27 PM
CivicLeader's Avatar
CivicLeader CivicLeader is offline
Send a message via AIM to CivicLeader Send a message via Yahoo to CivicLeader
Agreed...
I've spent a pretty penny on my bolt-ons and I've only got the SOHC Vtec on my '97 Civic EX...
I would def. consider an engine swap first and then your bolt-on's from that point on. Also...like what was said earlier...what do you really want...if you're looking to "run 9's"...then an engine swap is a must....if you're only looking to increase your hp/performance...then just do the bolt-on's....and dress it up a bit...
At this point...do a lot of research, ask a lot of questions, and spend your money very wisely because before you know it....you're out of pocket in a big way and you only have 30-40 horse power to show for it...and that's w/out the dressing...
CL
Old 08-06-2003, 07:24 PM
maby the real question is how fast do you want to go? and with a coupe and full interior?
Help with new car audio; Cade.Garrett Car Audio 2 07-02-2009 12:32 PM
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
jdm h22 help sanchezjarodsdad JDM Motor & Parts info/chat 4 04-09-2009 05:14 PM
97 ram 1500 sport 4x4 tranny problems HELP ME! tabes Ram Pickup | Ram SRT10 3 03-14-2009 08:56 AM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
