Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-24-2003, 07:36 AM
sursh79 sursh79 is offline
Unhappy Maxima 'changes' after ECU change...
So thanks to all your advice -- I did figure out that not only were 2 fuel-injectors gone ..but the ECU was not sending signal to one ...
I had dealership confirm all this - and got another mechanic to replace the ECU ...couple of results:
-- now with the new ECU - I could not find the exact *same* ECU model/serial# but the one I got was for the same prod-month/year also ..strange?? but anyway - the engine light is constantly ON
-- 2nd problem is that -unlike before- the car shifts very hard - too hard into 2ND gear ..a noticeable 'thud' which could give an old man whiplash!
Why is this happening?
For us regular no-access to dealer types -- once I do check the ECM long/short light flashing ..how do I know what the code means?
Does anyone have a chart explaining ECM codes?
Will re-setting the ECU help? I just learned that u can reset the ECU from inside the passenger compartment - has anyone tried?
..ok too many questions - I will stop.. hope to have it runnin smooth ..this car has been all over the NEVADA desert (mojave) and AZ ...too many memories to give up on it!!!
Old 07-24-2003, 08:14 AM
NJMAXSELTD NJMAXSELTD is offline
Is your new ECU from a 5 speed? If so, you'd better start hunting around for an ECU that was in a Auto.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 07-24-2003, 10:10 AM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Yes, you can reset your ECU and you should look for one for an auto or just reset it and drive it around for a couple of weeks so that it can learn your driving habits/pattern, once it does you should be fine.
By the way, it should read bk2k3Max, not bk2kmax.
Old 07-24-2003, 10:12 AM
No the ECU was from the same month/year/model & auto (not manual) -- the wreckers asked me all this before sending it. And their a reputed well-known auto-parts wrecker here.
I cant seem to find any posts to see
-a- what different 'funtions' the ECU is responsible for
and
-b- how the ECU could affect tranny // gear shifting... whether its modifi-able...
hmmm...
Old 07-24-2003, 11:17 AM
bk2kmax's Avatar
and
hmmm...
Sursh, try this site, it might help:
http://www.brianv.net/mods/ecu/
