Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 07-23-2003, 11:39 PM
Billy Markham Billy Markham is offline
Tempo's intake manifold?
Where is the intake manifold located on a 1992 Ford Tempo?
Where is the throttle body?
Thanks!
Old 07-24-2003, 08:45 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
On the '92's, the intake manifold is the big aluminum thing behind the engine, next to the firewall. Pictures available at www.tempotopaz.com if you're interested.
I've got an '86 with CFI, so I'm not dead certain about the exact location of the TB - but it may be integrated into the manifold.
Dagr8Tim will know, off the top of his head more than likely.
5 bucks says he'll see this post before 12:00 noon. He's almost as big a T/T zealot as I am!
Old 07-24-2003, 09:22 AM
Manifold leak?
My problem is that myTempo starts, then dies promptly. I crank it up and it always starts again (so far), but it sounds like it wants to die every time I pull up to a red light. I was told there might be a leak in a vacuum hose attached to the intake manifold.
Old 07-24-2003, 04:52 PM
pcv pcv is offline
If you have a vacuum leak, you will hear a hissing noise, like air escaping. Follow it and replace or repair the hose. Even with the engine off, follow all the vacuum hoses and make sure they ar not leaking.
Onother thing you need to look at is the ignition coil tower. Take the ignition wire off and clean the terminal. They get really corroded and can cause you problem.
NOTHING LIKE AN OLD CAR.
Old 07-24-2003, 07:38 PM
Ignition wire
PCV,
Where's the ignition coil tower?
Thanks!
Old 07-25-2003, 12:27 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Ignition wire
Originally posted by Billy Markham
PCV,
Thanks!
which engine do u have the 2.3 I4 or the v6???
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 07-25-2003, 08:08 AM
Engine is 2.3
Old 07-25-2003, 08:36 AM
pcv pcv is offline
Follow the middle wire on the distributor cap(probably covered by rubber), it will lead you to the ignition coil. Between the engine and tranny, towards the radiator.
