Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-23-2003, 05:20 PM
Z31Turbo Z31Turbo is offline
Send a message via AIM to Z31Turbo
RB20DET for my Z31?
I have a 1985 300zxT, The engine/turbo is going bad and i was wondering if anybody knew about a RB20DET swap. I have found a website with the Engine, transmission, ecu.............. Will this engine bolt right in or would it require a lot of time and money. If so what is another good engine to consider, Thanks
Old 07-24-2003, 12:15 PM
Henry8866 Henry8866 is offline
Won't drop in, but it won't require a whole lot of money either. A suggestion for another engine would be a rebuilt vg30et. Why bother with another engine?
Old 07-24-2003, 12:25 PM
k6kicker k6kicker is offline
Send a message via AIM to k6kicker Send a message via Yahoo to k6kicker
i have seen it don, you might want to try asking some guys in the zcar.com forum or maybe concider a rb25, not much more expensive, still would fit, and gives alot more power, an sr has more potential then a rb20
It sucks out there and I'm never going back
Old 07-24-2003, 04:44 PM
I had seen the RB20DET motor and thought it was an awesome motor, skyline, i had seen something called a 200zr i think with a RB20DET but it might have been a SR20DET, it had a top mounted intercooler, i just wanted to have an engine that nobody else has, something different, Also what are the specs with a RB25, thanks
Old 07-24-2003, 05:12 PM
top mounted i/c...sounds sr to me....rb25...lemme dig up some specs for you (i'll try to find external demensions) but have you ever thought of getting a vg30dett...its a great motor
Old 07-24-2003, 05:18 PM
Valvetrain dohc 4-valve/cyl
Displacement [cc] 2498
Bore & Stroke [mm] 86.0 x 71.7
Compression Ratio 9.0:1
Redline [rpm] 7500 fuel cutoff 8000
Max. Power [Bhp at rpm] 250 at 6400
Max. Torque [lb-ft (Nm) at rpm] 217 (294) at 4800
Bhp/Liter 100
but i cant seem to find some external dimensions, i can't see why it would be much smaller then an rb26...so you can refernce from that to see how much work would be needed to be done
would you be talking about the 90-96 Z32 Twin Turbo motor, if so that is an awesome engine indeed, if that would drop right in that would be another thing for me to consider, let me know, thanks
Old 07-24-2003, 05:21 PM
yep, same motor mounts and everything, and a domestic motor so parts wouldnt be hard to come by
Oh, would the RB25 mount in with ease, i don't have a whole lot of money to be spending on extra labor so i need an engine that would be fairly easy to get in the car, i am not saying that i couldn't find the money somehow if it was an awesome motor
Old 07-24-2003, 05:24 PM
also if you can find a wrecked n/a z32 or just a plain old vg30de (n/a z32 motor) the turbo conversion is rather easy and makes alot of sense actually...you end up with a fresh engine with better internals and the turbo you want, why start out with a turbo and pay the extra cost for stuff you would have to replace anyways if you wnated to go big......also a vg30de puts out more power then a vg30et does stock so the n/a route might do you just as well
Old 07-24-2003, 05:25 PM
Sounds like a good plan, i will have to look into that, i still woud like to consider the RB20DET or the SR20DET
Old 07-25-2003, 05:33 PM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
200ZR uses a RB20DET powerplant....... that engine is far more sportier then the VG30ET......
RB series kicksass and takes names with some money spent.
Old 07-25-2003, 07:28 PM
How much money spent, also if something happened to the engine wouldn't it cost a lot to fix it? Thanks
Old 07-25-2003, 08:16 PM
S14Kyle's Avatar
S14Kyle S14Kyle is offline
Send a message via AIM to S14Kyle
Fairlady body never came with an SR in it...
I <3 Nissan
Yo, yo, yo, pimp juice. I've got the bling bling hookup, biatch.
Old 07-27-2003, 12:59 AM
n2o4ever's Avatar
n2o4ever n2o4ever is offline
Also got a question bout the Z32, i kno its been tlked bout LOTTTTA times but watever, If you drop in a rb25 or rb26 engine(i think one of them is awd) how much custom fabrication will be needed? cuz i kno the engine space is squished and the vg is wider than the rb26/25?
Is an RB20DET engine legal Anthony714 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 08-07-2010 05:36 PM
Rb20det Engine Hks Fule Computer For Sale For Z31 And R31 Skyline masood Classifieds 1 09-26-2005 09:47 PM
rb20det into z31 solidtimh 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 03-20-2004 12:51 PM
rb20det engine mounts for z31 feenix z 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 03-11-2004 04:11 PM
RB20DET into Z31 ShinRekka 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 2 12-10-2003 12:20 AM
