Engine Went Crazy On Me. errrrr
Last night I was driving home, With my system cranked up.
Everytime I let off the gas the car kept driving for like 2 seconds. So I turn down the tunes and hear my car reving on it's own. I came upto a red light, came to a dead stop with the car in nuetral and my foot on the clutch. The car started reving on it's own. Scared the fuck outa me. PLEASE can anyone help me out???? I need all these problems worked out for when I make the drive down to the states. Thanks in advance |
I dont think your car wants to cross the border
![]() are all your vacuum lines connected?
SOLD!
throttle cable could have shit in it, or ur springs might be loose, the ones that put pressure on it to return it to normal, mine did this, still does, tried fixin it but think its the springs now ot throttle cable 2 tight still
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
Yeah, sounds like the throttle cable is sticking on you, or the throttle itself...
What I would do is start the car, and pop the hood. Then pull on the throttle cable by the throttle-body and see if you can get the same thing to happen... If it does happen, since you'r not really using the cable, that would seem to me to indicate that it's the throttle body. If it doesn't happen, but you can get it to happen when you use the pedal, then I'd say it's the cable. Hope that makes sense.
could it be the automatic choke playing up ?
i know mine did on my vauxhall, and as soon as i popped the hood the fucking thing stopped reving
Jim - Your Resident EDM Biatch B16A1 I/H/E 4TH GEN UK SITE Honda Civic EE9 1.6-i VT |
Mine has done that before too.. Like, it has a surging idle when you stop?
Check your vaccum lines.. My problem was the fast idle valve, but I'm not too sure if D series have that.
"The nympho of info, I'm fuckin' what ya heard"
I really dont know if this will help but every single Honda I have had has done it. My 91 prelude did it when it was cold and my last 96 accord did it all the time.
I had it checked out on the accord by my mechanic and he said something about the idle control relays. I am not really for sure if the civics have the same engine componets but that is just my 2 cents. I would be sittin at a light or stop sign and you would hear the motor rev back up to a little above 2 grand sometimes it would even hit up to like 3 grand. It would do this all the time not just when the car was cold. Well I hope this helps. |
mine is actually doing it right now. like when i start the car in the morning it revs up to like 2k for like 15 seconds or until i start driving the car, and when i stop it idles alittle bit
Y LOOK FAST WHEN YOUR NOT?????????
my moms accord does this .... cant say that ive had problems with my civic though.
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
TPS or a vacume leak
********** My 94 SS ********** 90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car |
id say its either your TPS acting up or your idle speed adjust
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Same thing happened to me, turned the idle screw down a bit, and it went away.
10 PRINT "MARC-OS 0WNZ J00!!!" 20 GOTO 10 RUN 4/8/04 - My CRX is officially dead, RIP Lucy
Thanks guys!
It hasent happened again, and i havent done anything But next time it does I'll be prepaired! Thanks again guys! |
::makes scary whooshing sound:: or maybe you're car's just POSESSED!!!
![]() __________________________________ 1997 Honda Civic CX Hatch |
